turbojay240z »
https://forums.nicoclub.com/turbojay240z-u104667.html
Fri Oct 23, 2009 2:17 pm
Wow....i've been a member here for over a year and this is my first post....I started this project over a year ago. Progress has been slow until now.So, here we go.....
I have two goals in mind:
1st....it must appear to be as close to stock as possible on the outside.....no body kits, crazy paint or graphics...ect. The two reasons for this....1. the police here are A**holes to pretty much anyone with an "import".....and 2... i have always been more of a "function over form" type guy.
2nd.....Make at least 300whp, be my DD, and tear up the autox course on weekends ....should be easy enough with the setup i'm planning to use. Adjustable suspension will be a must.
These two goals are the reason i decided to name this project..."Sneak Attack"
Anyway....
Here is a list of the mods so far:
* bought but not installed yet** need to buy
Block .020 over....at machine shop right now.Wiseco 9.0 to 1 comp.Eagle rods…Polished head w/ new stainless valvesAll emissions removedT3/T4 turbo 50 trim A/R 60*JGS oil feed and return line*Recirc. Bov *Wastegate**24 x 12 x 3 intercooler*Aluminum under drive crank pulley
Transmission stock:
Stage 4 clutch**Fidanza 11 lbs. flywheelShaftmasters aluminum driveshaft 11 lbs.Stock v.l.s.d
Fuel system and electronics:
780cc injectors** from SLSOBDII to OBDI conversion harness....made it myself for $25S13 tuned ECU.....or maybe Nistune...haven't made up my mind yetWalbro pump**AEM wideband a/f gauge**SAFC II to fine tune ecu**
Suspension, Brakes, and Wheels:
KYB struts front and rearTenzo 2” springs…they suck…looking for something elseZ32 brake calipers front and rearDrilled and slotted rotorsR33 Skyline e-brake cablesZ32 TT 16” x 8.5” wheels225/50 R16 tires20mm H+R spacers
Inside Stuff:
R32 GT-R steering wheelAutometer boost, oil pressure gauges
And paint....someday
This is what i started with....What a mess!
Modified by turbojay240z at 5:33 PM 10/23/2009
Modified by turbojay240z at 8:06 PM 10/25/2009
Modified by turbojay240z at 6:55 PM 10/26/2009
