Project S14 2JZ
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
Acidz
Car: 1995 Nissan 240SX w/2JZ
Big things to be posted later in the day....
90mm TBTurbo Manifold finishedBrembo Brakes for the rear 4 pot Metal HeadgasketARP Head studs
Modified by Acidz at 5:25 AM 10/5/2008
Acidz
Sept 5th 2008--------------
Updates
The Newest update is i have now gotten my turbo manifold finished! YA! I also picked up the 90mm TB from a Q45 this thing is huge! I got a nice set of Brembo RSX brakes which im gonna custom make a bracket to use these as my rears! WOW! lol gotta get them painted black as the red isnt gonna match the fronts The head gasket and Studs i should have them tmr in hand can't wait.
Also getting the 90mm TB custom fitted to my intake manifold and got my runners and upper intake gasket matched so should put out some nice flow numbers later with the built head
I have pics for some stuff besides the 90mm TB + head gasket & studs should have some more as the week develops.
To Show these are real!
datsun2jz
that is an awesome project!
Acidz
Head Gasket + Head Studs
RCA
Every thing is comming together well.
Acidz wrote:
Those amber corners and looking better and better
Modified by rcabrita at 5:46 PM 10/6/2008
Acidz
more updates to come....waitin on my intake manifold from weir and waitin on my fuel system
styc
did the 1jz bell housing and 7MGTE transmission bolt up fine?
Acidz
styc wrote:did the 1jz bell housing and 7MGTE transmission bolt up fine?
ya didnt have to much of a problem
Acidz
Small Update....
Muscle Car Style Hood Pins w. wire
RCA
Eh Never liked them, always like the recessed hood pin setup.Any more goodies????
Acidz
ya ill post soon!
Acidz
Ok so i got some updates a few more than last time, but im still waitin on my carbon fiber hood, tow hook & fuel system to come in.
I got my intake manifold modified to support the 90mm TB i got & also got the intake gasket matched to flow better. Just gotta get that part repolished Picked up a 10 gallon fuel cell, along with my driver side kick panel with JDM flare which im going to remove and mod to fit on my passenger side
RCA
Nice!
I didn't know the stock mani needed to be modded to support a 90mm TB.Also I have seen 100mm TB for the 2JZ FYI.Not sure if your interested but I thought it would something you would care about.
How much does a intake mani setup like your run?
I like using the stock unit so you don't need to relocate TPS sensor etc...
Also can you post before after dyno #s?
*I am assuming the mani was polished.
Acidz
OCT 18th 08--------------
so...this saturday morning i headed down to nu-seal and picked up my turbo housing and upper water neck still need to clean it up a bit more, but im sure u get the point
Acidz
rcabrita wrote:Nice!
nothing really its cutting the stock manifold & finding a 90mm TB also someone to weld the plate that has to be made
well not really regarding before and after dynos since i dont have a stock intake with TB anymore
Acidz
ok got some **** pics as i cant find my cam but whatever...
Carbon Hood + fuel system + engine bay pic
the fuel system isnt the full thing yet as im waitin for the custom feed and return line with quick disconnect so i can switch between 94 oct and race gas plus my both custom drop in tank setups...also still didnt get my fuel rail with injectors connected to my lower runners
should come together soon just waitin for my car to come home again so i can complete everything.
RCA
Nice
So you are going to have the abillity to go from 94 octane gas tank to race gas fuel cell by useing a quick connect adapter?
Same fuel pump just disconnect tanks?
Or am I confused.Looking good bro!
Also that CF hood isn't a cowl hood is it?
Acidz
I dont remember if i posted any updates regarding my cover, but all its missing is a nice clear coat. I got my intake manifold back its a bit dirty, but it will be cleaned up more after also got a better pic of the carbon hood. Also my 90mm Tb that i need to get polished still so everything looks good
RCA
I am happy you chose to stay away from the cowl hood
I am also assumeing you will keep your S14 a Zenki?If so people will at the fact that you are one of the few who own a clean Zenki.
Good job so far!
Acidz
i was bored so i decided to take some pics today lol wanted to see what the cover and turbo would look like...i think it looks awesome so far lol
Hihps14
Car: 95 240sx
Props to the swap can't wait til I start mine. Just have to get my rb sold
Acidz
Looking for some help people im planning on getting my cage done soon now...should I keep full interior like I was planning and keeping the bars along the pillars or removing the rear seats and going straight down to the towers??
Kalypso
build your cage around the interior.
the backseat doesn't weigh much, keep it. Also, your girlfriend and all her friends may want to pack in for a ride, and shower you with compliments while you whip them around.
RCA
Kalypso123 wrote:the backseat doesn't weigh much, keep it. Also, your girlfriend and all her friends may want to pack in for a ride, and shower with you while you whip them around.
Fixed!
Acidz
so i went to pick up my fuel cell today from the place i get all my stuff polished looks MINT!!
Kalypso
excellent build. the 2jz and the S chassisalready love each other,
but the wheel fitment makes this car exceptionally dope.
Acidz
So....Good news and bad news
The car came home today, but on the way home it fell off the tow truck which resulted in this....
My buddy is taking care of the costs to fix the fender and during all that I think the oil pan also is screwed so that also...On a lighter note can't wait to get started on it...LOL
Acidz
IT was up on a normal tow truck not a flat bed if everyone is wondering and well the steering column wasn’t locked in place and when he took a turn it fell off and thing that holds the wheel swung around and hit the fender and because it fell it landed on the tow trucks center part between both wheels it hit the pan so...lucky me I took off the front bumper before he came and get the car..
Acidz
so..some updates i guess my parents got a new dig cam so i took some pics with it.
working on getting the engine harness out to be redone and also to start working on the body harness. While all that is going on gonna be sending out the head for a clean and some other stuff
Also below is a pic of the pan
Acidz
SO got some updates //// Dec 14th 2008
1. Removed the Engine Harness2. Removed The Dash3. Removed The Exhaust4. Removed The Body Harness5. Removed The Stock Oil Cooler Setup6. Removed Front Gear Cover & Main Pulley for Polishing7. Removed Steering Wheel8. Removed Other BS
My buddy [Stefan] and i were working away on the car today trying to get everything out and ready for the next steps to come. I plan on moving my body harness into the car where the passenger air bag is.
Good day today! Pic below
Return to “Hybrids”
