Project S14 2JZ
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
RCA
^ Um turbo specs now!Also...I guess its time to move that fuse box!
Acidz
Car: 1995 Nissan 240SX w/2JZ
T72 wheel w/ Y2K housing in the front, P trim wheel with the big shaft on the turbine side, the turbine housing is a .96 A/R All Garrett components used. From what I was advised it is good for approx 850 rwhp
Compressor Specs Inducer mm. – 72mm Wheel Inducer – 4.030 Wheel Exducer – 2.840 A/R Y2K (front housing) Turbine Specs Inlet/Outlet Size5” OD intake 3 1/8” ID “exhaust” Bearing System – wet floating A/R Ratio - .96 tangentundivided Wheel Styles Stage III Wheel Inducer – 2.542 Wheel Exducer – 2.920
RCA
WOW!What kind of power are you looking to make?
Also how did you mount your 2J? It looks like a custom fabber mount?
WDRacing
rcabrita wrote:WOW!What kind of power are you looking to make?
I'd assume he's looking for the worst driveability a vehicle has ever had...like worse then the model T.
Acidz
ABOUT 600+RWHP on pump but like 750+rwhp on race
ya they are custom TDF mounts
Acidz
lo
lol why do u say that...its not that big the turbo lol....
Acidz
rcabrita wrote:Size of tire or width of rim?
i had a 275 for the front and 305 for the rear before i swaped them out for 245 f and 275 r due to the 305 havin problems fitting in the rear end....but i tell u after i finish the turbo and fuel and things like that i plan on gettin a 305-335 in the *** end of my car
WDRacing
Acidz wrote:lo
Bigger then it needs to be.
If you cram the Nitto 305s or bigger out back let me know the wheel config cause I'd love to do the same thing. At the moment I'm thinking 15/275-60's
Acidz
LOL i was going for the wow effect with the turbo LOL
as for tires im puttin on a 285 this year...and see how that goes but i do want to get a 305 under that for sure.
RCA
Hey Rene dont worry about WD, he's just a p0rn fluffer
hinds90
Car: 89 240 sx
Anymore updates with the XS power manifold also you got anymore detailed pics of your mounts.
Acidz
i sold the xspower manifold since i couldnt use it....I am getting a manifold custom made from a local
pics of the mounts no...sorry
Acidz
Well....Looks like the 240sx isnt coming out this year!!! lol
Decided to move it 1 step forward...
PLAN-------1. Custom Turbo Manifold - AUG 082. Fuel System Setup - SEP(OCT) 083. Head Work - NOV(DEC) 084. Custom Intake Manifold?(Maybe) - JAN 095. 6 Point Cage - FEB 096. Carbon Hood / Carbon Trunk - APRIL 09
Going to be gettin things polished for the car & other things along the way clean up the engine bay and remove some more clutter.
But we will see how that goes!!!
Anyways onto the updates....
Acidz
Awesome Look what came in today!!! [nothing crazy][lol]
RCA
Hmm Sweet stuff!If I remember correctly didn't you want like 600hp?
Wouldn't that require a second WG?
Acidz
no it doesnt really need a second one.
since im also dumping it out and not back into the exhaust
HolyShiznit
Car: Working on my car
rcabrita wrote:Hmm Sweet stuff!If I remember correctly didn't you want like 600hp?
A second WG is not determined by an exact horsepower number but more so by the air coming in from a turbo. On a 2jz a second WG is normally associated with a T6 type turbo set-up because the second WG is needed to control the boost (air). That isn't the most scientific explanation but I wanted to keep it simple.
Acidz the car looks awesome keep us updated.
Acidz
So...here is another small update.
I cut my throttle body tunnel off along with the traction control sensor, inside flap & motor. Now its off to get tigged to connect the front section & an extension added[example pic below] on to give me the extra space i need to add a coupling.
More updates to come.
Example.
RCA
Yea I FAIL, once again. It is the amount of "bypassed" exhaust that constitutes what size and how many WGs
+1 the car does look sweet
Acidz
Ok well...Updates....Not Really
AUG 16 08--------------
1. S15 Headlights are now gone [SOLD] Hood is next
2. Picked up my CRY02 last night after 1 yr and 1/2 LOL
3. Modded my engine cover last night so cam gears can be seen
4. Picking up my polished runners this week to be sent out for my full out fuel system in the coming weeks.
RCA
So when are you going to post the updates that I read in your signiture???
Acidz
soon son just working on the cash....i have pics on some of the stuff i got polished i will post them tmr
Acidz
so...small update on whats going down.
Fuel System should be here @ the end of the month & turbo manifold should be ready to go by the end of the month
i did some ambers on my car didnt forgot one of them at home, but i took pics anyways and well the bay looks like poop right now lol, but soon it will be insane **whats funny is i never put my bumper on right yet lol**[lazy] lol
also did get a few things polished but only have a pic of 1 thing will get more later & have a shot of both 240sx awesomeness lol
RCA
I like the ambers "look" but not on Champagne 240s tho.
That isn't an after market intake manifold correct?I am guessing its a polished OEM unit.
Keep the updates comming!
Acidz
i might end up going Green with the car later on and also yes they do sell aftermarket manifolds but dont really want to pay $1500+ for one and that is the oem one i just got polished
Acidz
SEP 26 2008---------------
The baby eater is making its way in
RCA
Sweet mother of Mary!
Its comming out nicely.IDK about green paint though
What's the parts list on this new set-up?
Also did you need to relocate the water pump neck?I hear it gets in the way and they make a "kit" for it, so I assume you needed to do the same?
Acidz
rcabrita wrote:Sweet mother of Mary!
what parts u talking about??
water pump neck no thats really only if u have a T6 flange turbo
also coming soon...Dual fuel setup muahaha big things
RCA
The part list for the new set-upei: Full Race exhaust manifoldGarrett GT35 etc...
But I read your signiture so I think you built one from scratch.
Duel fuel set-up?Of duel fuel pump set up?
Are you aiming for twin in-tank walbros or exterior pumps?Will you be going for a fuel cell?What kind of power/boost numbers will you be shooting for?
Acidz
soon i will post :
Return to “Hybrids”
