Red coupe »
https://forums.nicoclub.com/red-coupe-u19771.html
Thu Feb 16, 2006 12:32 pm
TSB's for a 82 datsun 200sx...Lemme know if you want me to look up any of these.
99-048K 10/07/2004 Battery - Testing Procedures/Replacement 01-005A 10/07/2004 Restraint System - Seatbelts Slow to Retract 04-094 08/20/2004 Brakes - On-Car Rotor Refinishing 03-093A 03/19/2004 Engine/Transmission - Precautions During R&R Procedure 00-027 03/15/2000 Tools - Nissan Essential Tool Shipment Summary 00-013 02/10/2000 Steering - Vibration/Brake Pedal Pulsation 99-044B 10/27/1999 Tools - Starting & Charging System Tester 94-012A 06/17/1999 Brakes - Judder/Steering Wheel Shimmy 92-062A 06/17/1999 Brakes - AMMCO On Car Lathe Operating Guidlines 99-017 04/01/1999 Audio - Speaker Noise, Cellular Phone Interference 98-110 01/15/1999 Interior - Squeak and Rattle Repair Supplies 88-152 11/21/1998 Tires - Vibration, Diagnosis & Out of Round Measurement 98-063 07/15/1998 A/C - New Leak Detector 98-060 07/15/1998 Body - Repair Guidlines for Rust & Corrosion 98-042 05/15/1998 A/T - Fluid Application 98-005 02/01/1998 A/C - New Connections & O-Rings 96-104 11/13/1996 Engine Controls - Precautions Electronic System Testing 96-100 10/23/1996 Cooling System - Fan Installation On Water Pump Flange 96-087 09/11/1996 A/C - Revised Procedure For Detection Refrigerant Leaks 96-032 04/17/1996 Engine Controls - Idle, Base Idle & Timing, Startability 96-011 01/17/1996 Antitheft - Security System Trouble Diagnosis 95-114 12/06/1995 M/T - Clutch Operating Cylinder Service Information 95106 10/18/1995 A/C - Refrigerant Oil Identification PI95016 09/28/1995 Remanufactured Starter/Alternator - Program PI95017 09/28/1995 Remanufactured Distributor - Program 95074 08/02/1995 Antenna - Inoperative, Rod Maintenance & Replacement 95070 07/05/1995 ECM - Green or Blue Relay Caution 95062 06/21/1995 Tools - Essential Release, Connector/Terminal Kit 95057 06/21/1995 A/C - Compressor Leak/Noise, Poor Performance 95059 06/07/1995 Engine Controls - ECM Testing Precautions PI95-008 04/05/1995 Enhanced Emission Inspection/Maintenance Program I/M240 95030 03/22/1995 Tools - Essential Tool Release, Engine, A/C 95005 03/22/1995 Fuel - Cold Weather Starting Tips PI95006 03/22/1995 Brake System - Noise Concern Explanation PI95-006 03/22/1995 Brakes - Noise Explanation 95-015 03/10/1995 A/C - Precautions for Repair/Installation 95017 02/08/1995 Engine - Oil Level and Grade, Driveability 94-100 11/08/1994 Fluids - Recommended Fluids, Lubricants & Chemicals 94-097 11/04/1994 Engine Controls - Engine Control Module Identification 94003 09/20/1994 Bumper - Refinishing Techniques For Plastic Covers 94088 09/13/1994 Body - Components Material Safety Data Sheets (MSDS) 94-077 08/04/1994 Emission - Inspection/Maintenance Program Overview 94-009 03/04/1994 Battery - Charging/Replacement Procedure 94-015 02/08/1994 Paint - Contamination Identification and Repair 94012 02/03/1994 Brakes - Judder/Steering Wheel Vibration Correction 94-011 02/01/1994 Starting & Charging - Systems Description/Diagnostics 94004 01/13/1994 Drivetrain - Differential Oil Recommendations 94-004 01/13/1994 Differentials - Recommended Lubricants 93-176 11/29/1993 ECM - Relay (Type 1M) Green or Blue Precautions 93013 11/16/1993 Engine Controls - ECM Identification 93-167 11/16/1993 Engine Controls - ECM Identification List 93161 11/05/1993 Engine Controls - ECM Testing and Notes 93148 10/15/1993 Electrical - General System Diagnosis 93075 05/25/1993 Interior - Aid to Diagnosing Water Leaks 93071 04/01/1993 Oil - Recommended Fluids, Lubricants and Chemicals 93-017 01/21/1993 Cassette - Poor Sound Quality/Loss of Channel/Jamming 92123 12/22/1992 Wheels - Aftermarket Chroming of Nissan Alloys 92086 10/13/1992 Fuel - Injector Replacement Guidelines 92083 10/08/1992 Maintenance - Cleaning Power Antenna & Wiper Blades 92062 08/18/1992 Brakes - Ammco On Car Brake Lathe Operating Guidelines 92005 01/23/1992 Steering - Diagnosis and Repair of Pull 92003 01/16/1992 Audio - Aftermarket Phone/Audio Installation Precautions 92-001 01/01/1992 A/C - System Changes As Result of R-134A Refrigerant ATRATB078 11/01/1991 A/T - How To Use A Pressure Gauge 91067 07/11/1991 Lights - Water Condensation In Lamp Lens 91060 06/13/1991 A/C - ACR-3 Refrigerant Recovery and Recycling Machine 91052 05/23/1991 A/C - Refrigerant Oil Availability/Recommendation 91051 05/23/1991 Seats - Care of Leather Trim 91049 05/16/1991 Alignment - Toe Specification Clarification GI91004 05/09/1991 CONSULT - Lithium Battery Replacement WB91001 02/20/1991 Warranty Information - Suspended Warranty Claims HA91002 02/14/1991 A/C - Refrigerant Oil Recommendations WB91002 02/01/1991 Warranty - Expansion of VOR Freight Reimbursement 90099 11/08/1990 Tires - Recommendations For Winter EM90009 10/18/1990 Coolant Tester - Calibration 90-090 10/11/1990 Tools - Angular Tightening Recommendation & Tools EM90008 10/11/1990 Engine - Angular Tightening Tools ATRATB028 10/01/1990 A/T - Engine Vacuum Testing WB90010 06/25/1990 A/C Refrigerant - Warranty Claim Reimbursement EL90002 05/24/1990 Audio - Cassette Player Maintenance 90-044 05/24/1990 Audio - Cassette Tape Player Maintenance BF90003 04/12/1990 Locks - Revised Torques For Door Lock & Striker Bolts HA90006 03/15/1990 R12 Refrigerant - Conservation/Recycling 90016 02/15/1990 A/C - Refrigerant (R12) Recycling ATRATB9002006 02/01/1990 A/T - Choosing the Right ATF GI89015 12/14/1989 Fuel - Recommendations ATRATB8930 10/01/1989 A/T - Math Part II BF89024 09/07/1989 Exterior Trim - Cleaning Textured Plastic Surfaces ATRATB8927 09/01/1989 A/T - Twenty Steps To Successful Repairs 89132 08/31/1989 Tools - Rivnut Installation 89131 08/31/1989 Brakes - Silicone & PBC Greases 89-131 08/31/1989 Brakes - Silicone and PBC Greases ATRATB8923 08/01/1989 A/T - Math Formulas Part I EL89013 07/20/1989 Audio - Radio Installation Precautions GI89008 05/18/1989 Poly-Groove Belt - Tension Inspection EF87005 03/23/1989 Ignition - Transistor Unit Application Chart 89015 02/09/1989 A/T - Slow Shift, Replacing ATF EL88021 11/10/1988 Audio - Cassette Tape Player Diagnosis & Maintenance BF88015 09/15/1988 PDI - Paint Guard Coating (PGC) Removal BF88012 08/15/1988 Mirrors - Installation of Glass On Door Mirror 88025 02/22/1988 Engine - Block Heater Precaution 88015 02/15/1988 Chassis - Warnings for Aftermarket Rust Proofing 88-015 02/15/1988 Body - Warnings for Aftermarket Rust Proofing 88013 02/08/1988 Paint - 2 and 3 Coat Pearlescent Finishes ATRATB889 02/01/1988 A/T - Identification HA87023 12/21/1987 A/C Blower Fan System - Inoperative BR87009 12/21/1987 Rear Disc Brake Caliper Socket AT87172 11/23/1987 A/T - Cleaning Hydraulic System Components 87-172 11/23/1987 A/T - Cleaning Components/Overhaul 87-145 09/28/1987 Paint - Spotting Prevention & Repair ATRATB8754 09/01/1987 A/T - Front Bushing Wear 87-130 08/24/1987 A/C - Heater Gurgle Noise ATRATB8748 08/01/1987 A/T - Slipping or No-Shift/Metal Sealing Rings BF87026 07/27/1987 Seat Belts - Extender Availability 87-103 06/29/1987 Brakes - Explanation of Common Noises BF87017 05/18/1987 Windshield - Repair Kit BF87013 04/20/1987 Lights - Isopropyl Alcohol Caution AT87003 04/20/1987 A/T - Slow Shift In Cold Weather 87-064 04/20/1987 Lights - Plastic Lens Isopropyl Alcohol Caution HA87004 02/27/1987 Defroster - Poor Performance Explanation EF87004 02/27/1987 Fuel - Injector Replacement Interchange BE86020 10/23/1986 Audio - Radio Installation Caution GI86035 10/17/1986 Powertrain Components - Rust Proofing ST86007 10/03/1986 Power Steering Gear - Correct Oil Seal Installation EC86010 07/11/1986 Engine Controls - Oxygen Sensor Description & New Torque AC86011 07/10/1986 A/C - Component Service Kit EE86007 05/15/1986 Battery - Designation Modification GI86008 03/13/1986 Wiring Diagram - How To Read Instructions GI86006 02/17/1986 Engine Oil - Production Oil Viscosity GI86001 01/14/1986 Engine - Winter OIl Recommendations TS85046 04/24/1985 M/T 5th Gear Syncro Hub Shifting Inserts - Revision TS83042 03/01/1983 Steering - Whining/Groaning Noise TS83043 03/01/1983 Differential - Rear Brake Judder/Groan TS83020 01/01/1983 Speedometer - Noise & Pointer Vibration TS83012 01/01/1983 Child Restraint System - Front Seat Belt Locking Clip TS82105 12/01/1982 Cylinder Head - New Gasket & Torque Specifications TS82094 11/01/1982 Brake Pads - Abrasive Coated Design TS82068 08/01/1982 Propeller Shaft - Vibration/Misalignment TS82058 07/01/1982 Engine Valve - Clearance Adjusting Revision TS82075 07/01/1982 EFI/ECCS - Cleaner/Tester Machine Operation TS82042 07/01/1982 Brake Booster & Pedal - Factory Revisions TS82066 07/01/1982 Body - Rust Prevention TS82070 07/01/1982 Rear Brakes - Groan/Judder When Backing TS82061 07/01/1982 M/T Clutch - Shudder/Judder TS82050 05/01/1982 Engine Oil - Factory Break In Oil Reddish In Color NPB8228 04/29/1982 Tires - Replacement Part Numbers/Applications NPB8205 01/01/1982 Block Heater - Instructions For Installation
