DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Sun Nov 12, 2006 7:45 am
yes, there are obvious signs.
at first, you wont really notice anything, you mihgt just lose a little mileage.
eventually it'll get so bad that you're mileage will be down to about 20mpg, i think i even got less once stage three hits.
stage three indicates a total failure of te cts. this is really the only time you'll notice a problem has occured. the power will be down really bad. you may not even notice how slow your 240 has gotten, because it occurs so gradually.
what happens is, once it warms up, the computer starts to read from the cts as one of its main sensors. however, the cts will be so out of spec that the ecu knows to run in a safe mode. you'll lose up to 28 horsepower down low, but at around 5300 rpm, the motor will seem to pick up a lot more. dynos show a Huge peak in power at this point, and its only down 8 horse over stock.
so really thats it, it has to have gotten so bad that its entirely out of spec for you to really notice it. look for a huge power spike at 5300 rpms.
but, if you dont want to wait for that, warm your car up really, really well. then test the resistance across the two terminals and compare it. your warmed up car should 190 F, so the resistance should be close to that value.
the second test is to unplug the cts. then drive it. once it warms up, you should notice the 5300 rpms spike. if you dont notice a difference, chances are you have a bad cts, and have been slow for a while.
but the best option is to check the resistance against the value in the fsm
