KATwo40 »
https://forums.nicoclub.com/katwo40-u25350.html
Sun Dec 03, 2006 9:17 am
I ran my engine up to a little over 200k miles, with the last 50k being under boost. I also experienced choppy idle from time to time, despite cleaning the IACV and AAC unit.
At this point, with so many miles on your engine, it could be a combination of things, such as clogged PCV valve (VERY hard to get to while the intake manifold is on), worn out rings, leaking injector O-rings (which will also give some driveability issues) and the list goes on.
Your next step might be a compression test, just for kicks and laughs. You might find that all four are just down pretty far and that's that.
As for the color on your plug, it's tough to tell without seeing the plug. Perhaps you could post a photo of it?
Hope we can help you out with it, or at least find the cause.
