PoorManQ45 wrote:wow, you guys like to waste money.
why not step up to oxygenated 112 for $7/gal. then you'll get some real results, and it's ONLY $80 more per 20 gallon tank!
if the car doesn't require it, don't waste money!
But it won't gain you anything but a burned out cat if you run 112. If you run premium in a vehicle that calls for premium you will notice a change in fuel economy over running regular. That change in fuel economy might just be enough to make the 4 dollars worth it.
lets use 25 mpg as an example: 20 gallons will get you 500 miles, if you bought regular that 20 gallons cost $56.
You could run premium and get 27 mpg: 20 gallons will get you 540 miles, you paid $60.
Premium is 9 miles per dollar
Regular is 8.9 miles per dollar.
Not a huge difference, barely noticeable. But over a year it will save some money, and the car will have less problems in the future.
Putting premium in your bone stock 240 will do nothing, but newer cars are smart, they know what to do to maximize their efficiency.
Putting race fuel into anything that isn't tuned for race fuel will get you nothing, its not like it burns more powerfully, it just allows you to run higher pressure and more advanced timing without knock, if you have not tuned a car to run higher pressure and more advanced timing, the only thing that $7/gallon gets you is a nice smell and a destroyed catalytic converter.
