The KA is a truck engine designed for heavyduty high torque operations which is why they used it in harbodies and frontiers for soooo long.... The KA is a dog with fleas and should never ever have been put into the usdm 240 -- guess that is why they did not sell many s14s here.....spooled240 wrote:there's two ways to do a ka, makeshift and professional..both have been proven to work. The ka has oil squirters on the pistons and it has pretty beefy internals as if it was designed to be boosted. In reality, forged pistons and maybe a little headwork is needed to make a reliable 300whp ka-t.
Poor aftermarket support is a problem, but its gotten a lot better in only a few short years. Also, iron block, aluminum head, Ive never liked the idea of mixing the two.Kalypso123 wrote:what is the KA's greatest weakness
Mitsu has used this turbo setup on their cars for 2 decades only recently did they switch to all alum. blocks and heads.FlatBlackIan wrote:
Using the 4G63T as a testament to iron/aluminum's reliability? I here where you are coming from, but probably not the best comparison. I personally don't like replacing head gaskets.shift_SRDETuser wrote:
intriguing... so I suppose with heat; aluminum expands faster then iron.FlatBlackIan wrote:iron block, aluminum head, Ive never liked the idea of mixing the two.
I love mine even more since it runs now!!!!!!!!! JDM_Planet on ebay has NEW wiring harnesses for under $250...I have one and it works perfectly...not to much money if you ask mecorey240 wrote:Beater this beater that. If people did it right the first time, meaning. Replacing all sensors, oil pump, water pump, all gasket, wire harness done right soldered not rigged. The damn things would be fine. I cant afford it. And everytime one thing happens to mine. Another does. If I had the money, I would just replace my harness with a brand new one, and all the sensors. But I dont, so as of last monday, she sits in my driveay, once again. Awaiting the 4th turbo. I love it.
