Lokim »
https://forums.nicoclub.com/lokim-u160520.html
Thu Jul 29, 2010 7:29 pm
Well, you should be getting AT LEAST 144psi on your compression gauge. That is the spec's minimum allowable compression reading. The normal spec is 186psi with no more than 14psi difference between cylinders. Most motors won't even run if compression is under around 100psi. My suspicion is that either your cam timing is incorrect, your valves are leaking, or one of your heads is cracked, warped, or otherwise not sealing correctly. You'll need a leakdown tester, air compressor, and a mechanic's stethoscope to rule it out. You'll need to pull the valve covers and set each cylinder on TDC with all 4 valves closed (cam lobes up) and leakdown test them one cylinder at a time. Very time consuming, but the only way to be absolutely sure the cams are timed correctly and the valves are sealing...
