Infinitiguy19 »
https://forums.nicoclub.com/infinitiguy19-u84424.html
Sat Aug 21, 2010 4:47 pm
If you checked the codes correctly and the coolant temperature sensor did not show up on any known good ECU then its not the problem. I am not sure if the Coolant temperature sensor is defective it may or may not prevent the car from starting but I am not sure.
The Intake leak may not prevent the car from starting because when the coolant temperature (As relayed to the Engine Control Unit (ECU) by the Coolant Temperature Sensor) is cold *60F the engine was really rich. Its only at warm idle among other instances that the engine runs super lean.
Intake deposits should be non existent in your case where you rebuilt the engine.
So it comes down to the spark plugs which you replaced.
Check with a Laptop Consult, Nissan Consult or by looking at the LED mounted on the ECU to check the codes carefully.
