Got pics? maybe one of us can see whats up.toddnos wrote:ok, but the MAF was fine pre blox spacer AFAIK
pinched oil filler rubber:yep, that was my first thought, and turned out it was pinched in there. fixed that..still problem. also found that i had the stock gasket folded under...fixed that..still the stall problem.
im going to dissasemble and remove the stock metal gasket as described in the motordyne instruction as an option. and retorque in the progressive method as described.
anyone know a difintive way to check vacuum?there seems to be a plugged access port to the plenum.
no CEL.SteveTheTech wrote:
Installation of Intake Manifold Collector (Upper) If stud bolts were removed, install them and tighten to the torque specified below. Shank length under bolt head varies with bolt location. Installbolts while referring to numbers shown below and in figure. (Boltlength does not include pilot portion.) Tighten in numerical order as shown in the figure.: 4.9 - 6.9 N·m (0.5 - 0.7 kg-m, 44 - 61 in-lb)M6 Nut : 12, 17M6 × 25 mm (0.98 in) : 7, 8, 10, 11, 13, 14, 15, 16, 18M6 × 45 mm (1.77 in) : 2, 4, 5M6 × 60 mm (2.36 in) : 1, 3, 6, 9
If you have access to a scanner check your upstream O2 sensors. Here is some info on what they should be.
Specification data are reference values.MONITOR ITEM CONDITION SPECIFICATIONHO2S1 (B1)HO2S1 (B2) Engine: After warming up Maintaining engine speed at 2,000rpm0 - 0.3V ←→Approx. 0.6 -1.0VHO2S1 MNTR (B1)HO2S1 MNTR (B2) Engine: After warming up Maintaining engine speed at 2,000rpmLEAN ←→RICHChanges more than 5 timesduring 10 seconds.
Definitely sounds like a lean miss to me. Is your CEL on. If the TB is disconnected and the Idle Learn is not performed it may cause that but it would be accompanied by a CEL for a P0506.
sorry, that dosent quite cover MY issue.although i used your thread to install my plenum spacer.Beancooker wrote:All you need for the Plenum questions is here: zerothread/274245
btw im in moval too.no GF at the moment,, so that plan wont work..lolim home early from work, and letting the g cool down. i am going to follow the motordyne instruction manual to a tee. it is very specific. also removing the RTV because it obviously didnt help... then reset the ecu/TB.i will email you later and let you know how its going.Sentientbydesign wrote:
I would, but your email is hidden lol.
Just click my S/N and email me. I check all day long. I probably won't get out of work until 5:00-5:30. I'm over at UCR.
You got a gf/wife? Maybe I can bring mine along and they can compare notes about their "Nico-Freaks" hahaha.
Sorry, but you can't have my MAF. The last thing I want is two dead Gs.
You're a bigger liar than me (Says Riverside in my profile lol).toddnos wrote:btw im in moval too.
thanks dude, and if i can get this solved i might have you bring me a grounding kit too...Sentientbydesign wrote:
Ya email me and let me know if you want some help. I got the ecu and throttle release learning done in about 3 mins on the first try.
what kind of fix...like JB weld?Sentientbydesign wrote:I'm still leary about Kinetix. They're new plenums are supposed to be significantly stronger than the old ones, but the power gains are not as peachy as they say.
Want me to help you do a temporary fix on the plenum? If not, I would suggest checking out a pick a part or I can call my buddy who works at Infiniti to see if they have any laying around lol.
willing to try anything. i think im going to go look for some JB weld now. It is cracked right on the front left tab of the mani...i wonder if i can fix without removing the plenum againSentientbydesign wrote:JB Weld or something similar was what I was thinking. I also have composite expoxy at home (think Carbon Fiber and Fiberglass).
You could also take it to a welder who does aluminum work.
I'll contact my buddy.
its not going to be sealed shut. it is cracked around one of the front bolt tabs. i jb welded it...i am gonna try the carb cleaner trick to see if it is seal at the crack....thats a good one!SteveTheTech wrote:Holy crap that doesn't sounds like a good idea.
How are you going to remove it if you seal it shut?
Try using carb cleaner or a flammable spray around the plenum before sealing it shut. While the engine idling and see if the idle changes when you hit a certain area.
Satter66 wrote:Buy a Kinetics SSV. It's cool looking and it does work. I have one.
I have had no problems with the Kinetix plenum I own. The install takes an hour or less. Specially if you already have plenum experience. **Cough**toddnos wrote:i think i read that teflon has the black top kenetix.
wonder how he likes it?
lol, and i do have the experience now.. thanks for the pic and reply!i wonder how much different the powerband is compared to this blox spacer. the blox seems to kick in suddenly around 3500 rpm..does the keneix feal like that, or more punchy off idle?TeflonG35 wrote:
You can definitely feel the difference in Temperature. It cools faster and doesn't get as hot as the stock aluminum one.
My only complaint is that it looks kinda plain IMO. I'm thinking of painting it. Maybe just tape around the words and paint those a different color. Just ideas. Probably wont get around to doing it.
