plenum bolts torque specs *help ASAP*
toddnos
Car: 2003 infiniti g35 sedan
TeflonG35 wrote:The kinetix upper plenum connects to the TB. IT comes with new gasket and new hardware. Also it is like a cork material on the plenum that makes a nice seal as well.
DO NOT OVER TIGHTEN the bolts. It will crack the composite material on the kinetix plenum.
yea, i have an inch pounds torque wrench now. i learned my leason.thanks for the reply!how about the powerband? power comes on early or higher in the rpms?
TeflonG35
Car: 2003 G35 Sedan
Well the inside is smoother then stock and also it doesn't have the center screws. So It has a clearer air path. I honestly don't think there is any feel over a spacer. They should be pretty similar in gains. I do like how it doesn't get as hot as the stock plenum though. Anything that keeps heat down is a plus. Specially when it has to do with intakes.
You can combine a spacer with the kinetix plenum to add a few more HP. If you do that then the engine cover probably won't fit. Also you might not have clearance for a tower brace.
If you want engine response then go with under drive pulleys. I really forget how a stock G feels lol.
toddnos
TeflonG35 wrote:Well the inside is smoother then stock and also it doesn't have the center screws. So It has a clearer air path. I honestly don't think there is any feel over a spacer. They should be pretty similar in gains. I do like how it doesn't get as hot as the stock plenum though. Anything that keeps heat down is a plus. Specially when it has to do with intakes.
looking for torque more than horsepower. i dont want to rape it to get power. so mods that exploit torque in low revs appeal to me for the g.
i think i may still buy the grounding kit after the kenetix gets here. also i had a dream last night that i changed my spark plugs..so i think i will do that too..lol
TeflonG35
Car: 2003 G35 Sedan
You want mods that make your car more responsive. Get rid of the Stock cats, And get some underdrive pulleys. Also since you have a 03 sedan then you should probably convert to a mechanical fan. You will love your car after these mods.
toddnos
yea, i like the fan idea, i would like to set it up so its not powered by a switch like yours is though.also whats this about a 05 rear end conversion?better gears?
in socal the CHP have roadside dyno smog checks randomly. i used to roll without cats for years in all my cars and trucks, but not anymore. maybe some good HFC, but no test pipes for me anymore.
Sentientbydesign
Car: 03 Evo VIII - 330 AWHP
05 Subaru Legacy GT Stg 2 - Sold
05 G35 6MT Coupe - 278 WHP - Sold
04 WW Evo VIII - 302 AWHP - Ex's
96 I30 - Sold
On my list of things to do is build a fan replacement kit for the early sedans.
I feel like I've got too much on my plate as it its, but I'll announce when everything is done.
toddnos
recieved the kenetix upper plenum yesterday..woot!i am going to install it this evening when it cools down.
with the proper inch pound torque specs..lol
kmckis1029
Car: 2016 Q50 RS400 AWD
2010 G37x w/Prem, Nav, & Wood (sold)
2005 G35x w/Prem C (traded in)
what are you going to do with your blox spacer? i might can take it off your hands
toddnos
kmckis1029 wrote:what are you going to do with your blox spacer? i might can take it off your hands
i will see what it looks like.if its usable, i may combo it with the kenetix, if i dont like the way it looksi will give it up to whoever wants it.
kmckis1029
first dibs on your spacer! But i hope it works out for you...
toddnos
i didnt re use the blox spacer..its trashed.
The kenetix upper plenum blows the blox spacer out of the water IMHO.
Sentientbydesign
96 I30 - Sold
How do you thrash a flexible plastic spacer?
TeflonG35
Car: 2003 G35 Sedan
I dident know it was flexable @_@
I just assumed it was hard plastic. I'm pretty sure it will mess up if you over torque it. It's only plastic. Essentially its like putting plastic in a vice grip.
toddnos
TeflonG35 wrote:I dident know it was flexable @_@
exactly it is slightly flexable, but if over torqued will have mean grooves in it like mine. i will post some pix along with the cracked upper plenum.
toddnos
http://forums.g35club.org/zero...56486
^^check the kenetix v+ install with pix
toddnos
dammit!my g stalled againit fires up fine cold...i drive to work, and turn it off. i roll up the warehouse door, and get back in and start it back up, and it stalls. idle goes up as normal when started, but falls low and stalls.
there is no problem with this install.i am back to square one...i will try and reset the ecu and TB...it sux, because ive tried before, and could not get it into check mode.
it all started when i modded the plenum to begin with....
pffft...
Sentientbydesign
96 I30 - Sold
Didn't I tell you to troubleshoot the problem first before buying another plenum upper?
The offer still stands if you want some help. It took me 1 try and about 3 mins to do the ECU reset and throttle release learning.
toddnos
Sentientbydesign wrote:Didn't I tell you to troubleshoot the problem first before buying another plenum upper?
yea you said that, but the plenum was cracked through and through regardless and needed to be replaced.
cool, and i appreciate the offer...any time this weekend?
Sentientbydesign
96 I30 - Sold
Tonight. Or possibly tomorrow afternoon. Depends on if my appoint come through or not. Sunday is pretty booked. Super Autobacs in the morning, my dad's in the afternoon.
toddnos
Sentientbydesign wrote:Tonight. Or possibly tomorrow afternoon. Depends on if my appoint come through or not. Sunday is pretty booked. Super Autobacs in the morning, my dad's in the afternoon.
got me a date tonight, but i am free tomorrow morning through most of the day....i will email in the morning, and see how your schedule looks.
Sentientbydesign
96 I30 - Sold
That first line scared the **** out of me.
I was going to say, don't call me helping you a "date". I'm married sicko!...then I reread and understood better hehehe
toddnos
Sentientbydesign wrote:That first line scared the **** out of me.
yikes!dude, thats lol.yea, im going out with an ex Gf tonight in temecula.
Sentientbydesign
96 I30 - Sold
Sweet. Wife and some family friends were out there last night at Shogun off of Margarita and Winchester getting some Teppanyaki.
I personally like their sushi better than Teppanyaki.
Anyways, make sure you don't dive into the same problems that broke you up lol.
Wow this thread is off topic
toddnos
Sentientbydesign wrote:Sweet. Wife and some family friends were out there last night at Shogun off of Margarita and Winchester getting some Teppanyaki.
thats exactly where im going..lolits her fav sushi spot.
yea, im avoiding all talk of that stuff...just trying to have a good time..we have been broken up for 4 years, so its old news anyways.
Sentientbydesign
96 I30 - Sold
Just though of something...
You do realize that there is a Shogun in Corona right? It's on North McKinley next to the 24 hr Fitness.
Sorry, my head works in mysterious ways and I saw your post and it all clicked.
I'm going to assume that you either didn't know there was another Shogun, or the ex lives down there.
toddnos
Sentientbydesign wrote:Just though of something...
yea, she lives in temecula...and i think temecula is about the same distance or even closer from moval on a friday night anyways...
