Sweet. But we have bad roads so I'd like to go with a 45 in front. I don't need to go that wide in front although it would probably look bad ***. What would you recommend in front for a 45 tire?McRussellPants wrote:17x9 +15 Front 17x10 +25/35 Rear.
Done and done. Anytire you want will fit on the rear, and up to a 255/40 will fit on the front as long as you dont need to get to the steering lock.
or "full counter-steer"youngmanvr4 wrote:Steer lock means when your steering wheel is as far as it will go.
remember that that number isnt a measurement, its a percentage of the width of the tireEdub1 wrote:Sweet. But we have bad roads so I'd like to go with a 45 in front. I don't need to go that wide in front although it would probably look bad ***. What would you recommend in front for a 45 tire?
therefore the sidewall of a 255/40 is actually larger than the sidewall of a 225/45
I think you got it.Edub1 wrote:So, if I'm understanding this correctly, the offset or distance from the mounting face to the center line of the wheel, remains constant regardless of wheel size. So, it follows that the increased wheel size is split evenly on each side of the wheel relative to it's current position.
So 1" = 25.4mm increase on each side. So, increasing from a 6" rim to a 8" rim will give 25.4mm on each side of the wheel.
So, bringing the face 20mm closer to center as in a +20 offset would push the rim out leaving a only a 5.4mm increase on the inside and a 45.4mm/1.8" increase on the outside. A +35 offset would still yield a increase of ~ 1.2" to the outside of the rim.
Going to a +20 10" rim would add ~2.8" to the outside and ~1.2" to the inside. A +35 offset would bring it to ~ 2.2 outside and ~ 1.8" inside.
I think I'm going to make a wood disk and take some measures.
But then again this says nothing about the tires.
By the way, what is the largest size tire that fits properly on a 8" & 9" rim?
Is that a good blend of performance & looks? Remember, I don't have coilovers. What offsets?nismofly wrote:stretched will be better, to a point
running a 225 tire on a 6in wide wheel, no
running that same 225 on a 9.5in wheel no
running that 225 on say, an 8in wheel, yes
that said, on an 8/9 combo, id run either a 215/45/17, 235/45/17...or a 225/45/17, 245/45/17
Everybody loves to bash Eibach. I'm not 100% on this but I think that overall ride firmness has to do with the spring rate & the actual height of the spring. So, a stock spring when shortened becomes much, much firmer. So, when a slightly lower spring rate is combined with a shorter spring, the result is a ride that is more firm, but not too firm. Like I said, I'm not 100% on this but I think that's how it works.nismofly wrote:without coilovers, the 235 front will be close with +35 offset, but id say its possible
if you dont ever plan on getting coilovers, youll at least need a better spring than eibach, those are softer than stock
but if you ran a 8/9 stagger, id say +25/+35, then you could run a 235/45/17 and a 255/40/17
No, think if you compressed the stock spring an inch and started with that.nismofly wrote:well first of all thats not the case because if it was people could see vast improvements with cut springs, obviously completely false
