Edub1 wrote:Even with the extra 5mm on the front, I don't know why everyone likes the lower offset. A 8" rim with a +35 will come outward 30mm and a 9" +40 will come outward over 40mm. How can these look "sunk"?
If anything they should stick out a little.
i can answer this question. but i've completely given up on your tire fitment confusion over such weak sizes that are not anywhere close to fitment issues.
when i had stock 15x6 +40 wheels on a lowered s13. it was sunken away from the fender 2 inches(50mm~) or more (rough measurement). x8 +35 would somewhat save the sunk by 30mm which is still not close to enough. i recommended 17x8 +25~ because it wont be flush, but it wont look horrible, it most likely does not require fender rolling, crazy camber settings, and is an easy drop in fit. i'd honestly rather have something like 17x8+15 or lower over +25 anyday. 17x8 +35/17x9 +40 would be "put on classified" asap lol like FAST
flush, to die hard guys means 0mm sunk/0mm sticking out nothing in between. sunk would mean: wheel spacer, lesser camber, or get new wheels. sticking out would be: more camber, fender pull/modifying, or wide fenders
this thread was about the best looking setup without a fender roll/performance sacrificing wasnt it?
Modified by Juujai at 2:28 AM 2/23/2006
