Official M35/M45 (Y50) Wheel/Rim Thread
avishal26
Car: 2014 Infiniti QX60 AWD White on Black Leather Premium + Drivers Assist + Theatre Package
2011 Chrysler 300C AWD Loaded
2006 Infiniti M35x (SOLD)
2008 Yamaha R1 Raven (SOLD)
Car Model: M35x
Wheel Brand/Dimensions: American Racing Dale Earnhardt DMP DJ6331 - 20 x 8.5" all around, 5 x 4.5, +35 offset, weigh approx 30 lbs
Tire Brand/Dimensions: Toyo Proxes 4 (all seasons) 245/35/20 95W load rating
Suspension: Stock AWD suspension
Other Information: Have vibration issues :(
Pictures:
Before rims and spoiler:
Now:
sitting nice and flush with the body
Partysan7
Car: 2008 M35
Hey guys just have a question..I am shopping for wheels now and came a cross these Concept One RS-55's ( used ,in good condition and at a right price ) my car is RWD stock height for now, but most likely I`ll get H-techs in the spring
the wheels are
FRONT:
(2) 8.5" +30mm
REAR:
(2) 10" +38mm
these are rims only, no tires . Will they fit fine without any problem ,extra mods ,rubbing etc. ?! ( tires will be bought upon problem-free fitment )
Ilya
Car Model: 2007 M35x
Wheel Brand/Dimensions: 19x8.5 BE by Breyton GTS-AV +45
Tire Brand/Dimensions: 245/40/19 Continental ExtremeContact DWS
Suspension: Stock
Other Information: NA
Pictures:
polargice
Car: 07 M45
Partysan7 wrote:Hey guys just have a question..I am shopping for wheels now and came a cross these Concept One RS-55's ( used ,in good condition and at a right price ) my car is RWD stock height for now, but most likely I`ll get H-techs in the spring
the wheels are
FRONT:
(2) 8.5" +30mm
REAR:
(2) 10" +38mm
Find my posting on page 4. These are the wheels I have now. With the stock offset of +38 for the rears you will probably poke a little bit. I had mine milled to 42 so they would sit flush and also not cause an issue when lowered or loaded down.
Also, find 06M4.5's posting on page 4. He has Concept One wheels (different model) but same specs. He had his milled as well and he is lowered on H-Techs. His name is Freddie I believe, PM him. He provided me some good advice when I was shopping for my wheels.
2007 M45
Concept One RS-55
Front: 20 x 8.5 +30 (245/35 Michelin Pilot Sport A/S Plus)
Rear: 20 x 10 +42 (285/30 Michelin Pilot Sport A/S Plus)
Stock suspension (for now)
Partysan7
Car: 2008 M35
Polargice: thanks alot man those wheels are sweet !!! so you think I would be sticking out too much on the rears with +38mm offset ?! What if I ran instead of 285 tire a 275 tire would that make a difference ?! I want these wheels very much but i dont want to have problems with my M, its my daily/family car so i dont want to go too agrressive/vip to roll fenders. Just want a perfect fit that wouldnt give me problems
polargice
Car: 07 M45
I would recommend sticking with the 285 tire. I'm not too keen on having a stretched tire, but I'm also not an expert on tires. I went with what made the most sense based on what others did and also wanting to stay close to overall oem specs. I use my M as a daily driver as well and my current setup is great. No issues. Even loaded with full passengers and luggage I didn't have any rubbing.
38 vs 42 offset is only 4mm (about 5/32"), but for me, even at 42 it sits pretty much flush and I wouldn't want it out any further just from a looks standpoint. I can't say if 38 offset with those wheels would rub when loaded down. Probably not, but I'd have them milled if you have a good machine shop in town. Shouldn't cost much to do so.
06M4.5
Car: 2006 M45
the wheels are
FRONT:
(2) 8.5" +30mm
REAR:
(2) 10" +38mm
front is no problem but with the 38mm on the rear I would tell you to get the 235/ 275 tire set up.
now if you get the rear wheels milled to 42mm get the 245/ 285 tire set up.
My car in this pic now has D2 Racing coilovers. 30/42mm with the 245/285 tire set-up.
Partysan7
Car: 2008 M35
ok thanks a lot guys, can these wheels be milled from +38mm to +42mm offset ? thats 4 mm almost half a centimeter now would such milling affect strenght of the wheel, and if i do get them and mill them what about clearence on calipers ?!
polargice
Car: 07 M45
Partysan7 wrote:ok thanks a lot guys, can these wheels be milled from +38mm to +42mm offset ? thats 4 mm almost half a centimeter now would such milling affect strenght of the wheel, and if i do get them and mill them what about clearence on calipers ?!
Milling from 38 to 42 is no problem. There is extra space on the hub to allow for it without affecting the structural integrity of the wheels. I've had mine on for maybe 6 months now and they're perfect. Just be sure the shop knows what they're doing when it comes to wheels if you end up having them milled.
PlatinumM35
Car: 2006 Infiniti M35
Tein H-Tech Springs
Slotted/Cross Drilled Rotors
Wagner Ceramic Brakes
22x9 Status Wheels
Rear Entertainment Aftermarket
15'' RE Audio Subwoofer
Infinity Reference Door Speakers
2006 Infiniti M35
Suspension:Stock with Tein H Tech's -1.2 front and -0.5 rear
Wheel/Tire: Status Game S805 22x9 +40mm offset/Sunny SN3890 245/30/22
T.O.06M35X
Car: 2006 INFINITI M35X
Hey guys,
New member needing some advice on new wheels. Would 20"x8.5" rims, 5x4.5(5x114.3) bolt pattern and
offset of 35, with 235/30ZR20 tires work on a 2006 M35 with AWD?
Stock suspension
Thanks for any help in advanced!
polargice
Car: 07 M45
T.O.06M35X wrote:Hey guys,
Stock suspension
Sounds like everything would work just fine, although, I'd probably go with 245/35 tires since they're closer to the original overall diameter of stock setup.
The Bodyguard
Car: 08 Infiniiti M35 black loaded custom VIPDOUT
08 Infiniiti G35 S sold 92k miles
08 Infiniiti M45 S sold 78k miles
07 Infiniiti M35 traded 53k miles
95 Infiniiti J30 sold 155k miles
Location: Cypress, TX (Houston) o.g. from southern cali (North Hollywood)!!
Stock suspension
This set up is fine as far a the wheels go but you'll be better off with more rubber in there... 245/35/20 or I would prefer 255/35/20...good luck!
T.O.06M35X
Thanks guy. Ya the 235/30/20 is a little narrower than the originals but the tires were already on the rims and I got a really good deal on them both brand new. Would it make a significant difference changing out the tires for slightly bigger ones?
06M4.5
Car: 2006 M45
yes
go with 245/35/20
mexillis
Car: M45s
Not trying to debate but I think if you got them mounted already drive em til they're bald. 235 and 245 isn't something too drastic that you will notice a difference. The only thing major in sizes is the sidewall thickness. That's only gona affect ur speedo, off by 2 mph and maybe asthetics being so thin. One option is dismount, sell them and buy the "correct" size to be closer to the oem overall diameter.
White-Rush
Car: 06 M35S - Sold
11 M37S - Ran hard and sold
16 Q70S
Moving around a bit here, to another question.
- Does anyone know or have knowledge of what size tires, are being used with the M37/M56 - 20" sport wheels when mounted to the M35/M45 vehicles? I recall the specs on those being 20x9 @ +43. Stock tires are 245/40/20 if i recall.
I have a 06 Sport, and i'm set on grabbing a pair of these, but I need to know if the stock size tires will fit, or would I need to go down (ie.. 245/35 etc...). The car is setting at stock sport ride height right now, and i'll be adding a set of the Tein H springs along with the BBK to round things out. The car looks good at the stock Sport Ride height, so i may settle with the stock look, but then again a little lower will probably compliment the upgraded wheels better.
One last question.. On the Infiniti Parts & Accessories eStore, they have the wheels in a Gunmetal Gray Metallic finish listed for about $350 per wheel, based on my locale.. But on the Genuine Infiniti Accessories page, they are listed at $1752 with a Graphite finish. Which of the two are standard with the sport pkg? that's the color i want, not the darker color.
thanks for the space..
yosM45
Car: 2006 M45 Sport Twighlight Blue
White-Rush wrote:Moving around a bit here, to another question.
Did you ever get these? I'm dying to see them on a 06-07.
zerg711
20" Volk GT-C dropped on H-tech.
White-Rush
Car: 06 M35S - Sold
16 Q70S
yosM45 wrote:Did you ever get these? I'm dying to see them on a 06-07.
- No, for a few reasons.. 1st. i'm out of the country until late Summer/ early Fall. 2nd. I'm becoming more and more confused on what setup I want to go with. Playing with the Idea of using either the M37/M56 Sport wheels, or the Vossen CV3's. I also ran across some of the newer WORK Varianza's that I like also. 3rd. As a few of the other guys mentioned before, for the price of these wheels, you can get almost anything you want, wheel wise. That is, unless you find a cheap set on EBay or CraigsList or etc...
I just sourced a set of Tein S Tech for my car (for temporary use), and depending on which set of wheels i go with, will determine if the D2 coilovers will be next or the BBK. for the Vossens to look good, It's almost essential that you go with a BBK.
Back on topic - Heres a link to the setup you were asking about. 2006-infiniti-m35x-with-m56s-20-rims-t503666-30.html.
grine2wine
Car: 2007 M45 Sport/ 2004 G35
I MAY BE LOOKING TO SELL MY STOCK RIMS WHICH ARE 07 M45 SPORT OEM FACTORY "19 RIMS. I'M TRYING TO GET SOME CHROME 19'S OR 20'S BY TRADE OR LETTING THESE GO FOR $2200 (TIRES INCLUDED WITH ABOUT 90% TREAD LIFE REMAINING)
PM ME FOR MORE DETAILS. NO LOWBALLING!!
SdotSdotS
Car: 2007 Infiniti M35 Sport
I've had these since March this year (2012).
07 M35 Sport dropped on H-Tech springs
Wheels: TSW Rivage 20x8.5 +30 front ... 20x10 +40 rear
Tires: Hankook Ventus V12 245/35/20 front ... 285/30/20 rear
mistacard
Car: Infiniti M37x
I need help! I have an M37x....Can I fit 20" staggered wheels on it. The dimension of the wheels I want are 20x8.5 35 offset, 20x10 40 offset. Will those fit?
ctsedan
Car: 2006 M45 blk on blk. 1995 s14 Sr20DET.
Here are some M56 20"X9 OEM wheels on my 06 M45.
Some older GTR OEM wheels 2009 GTR 20"X9.5 45mm
My summer set up Iconz 20X9 F 20X10 R 255/35/20 285/30/20
[img]http://imageshack%20.us/a/img231/9950/dsc0406h.jpg[/img]
ctsedan
Stock M56 OEM wheels above are for sale, PM me for more info if intrested. Thanx
Cabo
Car: Infiniti M35 sport 2006
Nissan pathfinder LE 2002
What cash you looking for for the m56 stocks?
JoshTex
Got these 20" TSW's last week. Traded a guy straight up for my stock 18's. 20's have Nitto 555 tires with about 85% tread left on them.
I like them, prob gonna plastidip the polished bits this week. Tanabe springs are going on tomorrow.
PlatinumM35
Tein H-Tech Springs
22x9 Status Wheels
That was a good deal. You'll be on point once you drop that bad boy.
MILcityBOI
Car: 2008 M45x
235/30/22 on an 08' AWD
InfinM3506
Car: 06 Infiniti M35 Luxury Edition, Journey Package, Tech Package, Burnt Orange Leather. Eibach Pro Springs, 20" Vossen CV3 20x9 255/30/20. 20X10.5 285/25/20. 08 Front Infiniti Sport Changeout.
Vossen CV3's Staggered Setup. 20x9 Front on 255/30/20 and 20x10.5 Rear on 285/25/20 Wrapped in Nitto Invos. They actually ride very smooth.
