Official M35/M45 (Y50) Wheel/Rim Thread
Six_Legs
Car: 2007 Infiniti M45 Sport
1995 Nissan 240SX SE 5spd
Looks good! Any rubbing with the 10.5 wheels?
Amgberg
Car: 2006 m45 sport blue tint, STR 20x10.5, full Megan exhaust.
2010 E63 ////AMG stock
Six_Legs wrote:Looks good! Any rubbing with the 10.5 wheels?
thanks. no y50 can run 20x10.5 easy i run 245/35 all the way around but you can run 265/30 all around as well any tire size more than that on the front will rub.
Six_Legs
Cool, thanks! Been looking at wheels lately, hard to choose.
Amgberg
Six_Legs wrote:
Amgberg wrote: thanks. no y50 can run 20x10.5 easy i run 245/35 all the way around but you can run 265/30 all around as well any tire size more than that on the front will rub.
for good price look for the style you like 5 star 5star split spoke 7 star so on then i would refer STR nichie and stance because great price and good quality. then think about what type of style fitment aggressive 20x10.5 25/30+ offset 225/35 stretch. semi aggressive like mine 20x10.5 35/40+ offset 245/35 265/30 semi stretch. conservative F20x9 32+ R20x10.5 40/40+ offset F255/35 R275/30. my step up semi has been very good to me for daily driving had this set up for 2 summers and i drive my car in philadelphia winters.
KC611574
Car: 2009 Nissan Maxima S
Does anyone know if 20x9" +25mm wheels will fit an '07 Infiniti M35X (with 245/35/20 tires)? The car is currently on the stock suspension....for now.
Amgberg
KC611574 wrote:Does anyone know if 20x9" +25mm wheels will fit an '07 Infiniti M35X (with 245/35/20 tires)? The car is currently on the stock suspension....for now.
It will fit
acls2x
Hi all
I have a 2008 M45x with leaking air from corrosion around the valve stem on at least 2 wheels Size is 245/45/18 which i think is the stock size. I am thinking of replacing all four rims rather than repair/ Any suggestions on rims to replace the OEM rims with. I am not necessarily looking to upgrade. May try a repair but think I may want to just replace the rims
I have been searching tire rack. I believe the OEM width is 8 so its probably better to stick with that. The OEM offset is 47 mm. The closest I get to that with tire rack is 45 and 50 when I pick tilt cast with flow forming. Is one choice better than the other. I can get to 48 mm offset with low pressure casting. Theses are actually cheaper too but are they as durable?
macgiver
mac , this is on the repair side of things. I have gone with STEEL valve stems , which utilize two "sandwiched" silicone rubber washers that are extremely leak-proof and the switch was ACTUALLY due to a wave notoriously defective Chinese valve stems which FLOODED the World market since 2007-2008'ish , whereas the DISINTEGRATE with minute cracks and even completely brake open ! :rotfl I got them at O'reilley's and they snug - up with a double locknut , if a drop of Loctite is also used they are virtually FOOLPROOF & LEAKPROOF ! :yesnod
acls2x
I would like to still use the TPMS SENSORS. Right now there is a rubber valve stem in two of them. A local shop thought the leak could be repaired by replacing the gaskets in the tpms. They did not charge me for what they tried since it did not work
jaysmooth76
Car: 2008 infiniti m35x
acls2x wrote:
Sat Mar 10, 2018 7:44 am
You can get new ones from eBay that’s what I did
Skwirl865
Car: 07 m35
07 M35 with 22" velocity v12 rims.
22" will fit with no modification and no rubbing with the right offset and tire size.
Mine are 22x8.5, offset 35 with 255/30/22 tires
Stevem45
2006 M45 Sport
I have a staggered 20” setup that was on it when I bought the car. I just bought this a week ago today, and it’s been quite cold out. I haven’t been able to get a look at the wheels to do a proper measurement, but measuring through the wheel I can estimate 20x9.5 in the front, and 20x10.5 in the rear. 275/35 Pirelli snow tires on rear, and 225/30 up front. Don’t know offsets. I get some rub when I have back seat passengers, going over a bump.
I’m going to change them to 275/30 on the rear, and 245/30 up front. I’m not a fan of the stretch on those 225’s.
Amgberg
Skwirl865 wrote:
Tue May 15, 2018 2:14 pm
How does 22s ride?
