I just unlocked Echo and it isn't that bad. Yesterday I beat the two juggernaut levels on hardened pretty easily playing Solo (no XBL and my roommate hates playing anything that's "too hard")Vet is probably just like the other spec op missions, you just have to do what you did on hardened, only you have to do it twice as fast so you don't get shot lol.RCA wrote:
Also I plan on doing a pretty through run down of every Spec-Op mission. So far Echo is impossible
On High Explosive I just keep moving around buildings. Wait for the jugg to walk around the corner and blast them with a rpg, they'll either fall or keep running at you. If they fall, blast them again. If they keep running sprint around another corner and blast them again. I only used claymores as signals that one of them was coming up behind me, I dont think the claymores do much damage. There's also several buildings you can bait them through and blast the hell out of them through the windows. Flashes work well to get a free hit on them or if you're in a tight spot you can toss a flash and gtfo.I just ran completely around the outsides of the map, I rarely went into the middle. There's a nice little alley you can set up C4/claymores on the top right side of the map. I like the rpg better because it seems to make them stumble more, the thumper reloads faster but it's hard for me to knock them down with that.
Armor Piercing is more of a waiting thing. Just grab that .50 cal when you start. If you hit them in the chest, sometimes they'll double over and you can hit their head. I noticed that if I kill one guy then sprint as far forward in the map as I can, they'll eventually start spawning behind you. If you get to the top of the map, set claymores down by the door BEFORE the door that they walk through to shoot at you. This way you can just look down into the hole in the middle of the floor and shoot at the guys running through the map to get to you. Then if one gets by, you'll hear the claymores go off and you can aim at the door and get him as he comes through.
Wetwork is hard for me though, it took me a bit of work to beat that one. I have no good strategies other then duck for cover and shoot back and take out that helicopter asap. lol
Modified by otterman at 2:47 PM 12/28/2009
Modified by otterman at 2:48 PM 12/28/2009
