OldmanPurdy wrote:Can anyone who has the game comment of the effectiveness of shotguns? ie: are they a viable weapon now or is it still using the halo 3 5ft effective range school of thought?
Ive got the shotgun shell emblem, cuz i main the shotguns now. Ive got all of them to atleast level 3. And my faves are already complete.
Ill give you a review of all the shottys in core mode i dare not use them in HC.In order of perceived effectiveness lowest to highest.Based on Nalis' personal experiences with each.
5. Spas 12. - Too slow for room clearing, and its range isnt that great. Its comparable to the W1200 from COD4, but it actually fires slower....so pretty useless cept for emergency situations when you get flanked.Rating: Not worth wasting the slot.
4. W1887. - Awesome range, but a small clip, and relatively slow fire rate hurt it, to the point that it isnt worth main'ing, but is a really good secondary weapon. Much better than the Spas-12Rating: Lotsa fun but the slot can be used better
3. Ranger. - Decent range, and because it is double barreled its initial fire rate is very very high. Each trigger controls a different barrel so if you are too far to single barrel a guy squeeze both. Death from a distance....but only 2 shots means lotsa reloading. Sleight of hand will be needed...which means no bandolier which can be a bummer. But if you dont stay alive long enough to finish your bullets its a really good gun.Rating: Really good, and when first unlocked well worth main'ing for a while
2. Super 90. - Back from COD4 and nerfed cuz it was too powerful back then. The fire rate and range of the Super have been reduced slightly but it is still a very powerful gun and well worth main'ing it. Once you unlock its final attachment(no spoilers) it becomes a force to be reckoned with.Room clearing becomes very possible. It is also a really fun gun to run around with.P.S Dont put steady aim on it, and dont bother ADS. its more destructive without both.Rating. Badass. Perfect for main'ing and good use of a slot if you arent a camp style player. Better guns exist however.
1. Akimbo Ranger. - Lol wut, this gun again? Yes. The Akimbo Rangers stats are changed as such, it plays like a completely different gun, so it gets another spot.The Akimbo Ranger plays almost exactly like the Super 90 did in COD4. Which means its absolutely godly. It suffers the same distance issues the Super did, but with stopping power you only need a small percentage of the pellets to hit to get the kill. This gun is absolutely beastly on any map that has lots corners. Since you can reload two chambers independently of the other two. Killing guys who keep trying to rush corners is easy. 1.2 reloading 3.4 reloading.1.2 so and so forth till you run out of bullets or someone figures out to flankRating. Excellent main gun. probably the best gun to get the Game winner with as everyone Ohhhs and Ahhhs when they see its awesomeness.
0. Striker. - A gift from God, to every shotgun lover on the planet.
Its range is almost unfair, and people have already started complaining that the gun needs to be nerfed. It has a massive clip(by shotty standards) so clearing a room is a breeze....literally a breeze. Ive played matches where i get 6x multi kills without breaking a sweat.Its fire rate is extremely high so even if 4 or 5 guys jump out a door at you just keep squeezing cuz the shotgun has insane aim disruption so all their shots will hit the roof while your pellets will probably hit their heads if they get any shots into you. 4x Headshot anyoneAgain dont put Steady aim on this bad boy so you can get 2 or 3 guys at once.Extremely satisfying to kill 2 guys who are standing next to each other with 1 shot.Rating. Godly
-0. Kage Kage 12 - The Devil made metal. When you hear the kage kage go off, Unless you are sniping...run the other way very very quickly.Because, the kagekage user will kill you. It is nigh impossible to react to the onslaught that this gun unleashes when the trigger is squeezed. If you are in its line of sight, dont even bother trying to ADS. you will be pushing daises before you get one shot off. Its absolutely ruthless and makes short....short work of anything and everything in its path.Even Painkillers kneel before its awesome might.
It has the second highest range of all shotgun, slightly more than the Striker, it fires like its a frikkin SMG so itll clear its clip in a second. Meaning lots a reloading if you arent careful.However, this gun with stopping power only needs 2-3 shots at max range to drop someone, so instead of holding the trigger down, squeeze as needed and save bullets. It also has a ton of recoil which can be counter by careful aiming or the grip.Rating. Godslayer
A final word.All the shotguns have similar drawbacks which can prevent inexperienced shot-gunners from excelling.
1. Range is always an issue on the really open maps, but luckily the way the game is setup your secondary(?) weapon will alleviate that problem.
2. The enemy always knows where you are once you fire....so as soon as you do the flood gates are open and you need to be ready.
3. All of them have ammo issues, they all run out pretty quickly. It is possible to counter this with bandy. But sometimes the perk slot is better used for something else.
4. Breaking the habit of ADS is tough. The shotguns dont need ADS and IMO are actually better without it, so you will have to learn to stop ADS firing as it justs wastes time when it comes to the shotguns.
5. Hate from other players, because the shottys can be really ruthless.Lotsa hate because the shotguns dont care if you drop shot. Cuz the pellets which do hit now will most likely count as headshots. So if a guy drop shots, the shotgunner can just fire while aiming at where the dropshotters waist was and still get the kill by headshot no less.
P.S.Kage Kage. - The sound the AA-12 makes when you shoot it, youll come to hate it or love it real soon.Super 90. - M1014Akimbo. - Attachment(no spoilers)ADS. - Aiming Down SightsGun levels. - every gun has levels of usage much like in COD4. But this time even if you unlock every attachment, there are still more levels for the gun at which point you only get XP. But its an easy way to show other people your proficiency with any gun, as until you have reach the final gun level it will tell you exactly how many kills you have for that gun.
Hope this helped.As you can see im a huge shotgun lover.
Modified by Nali at 5:03 PM 11/10/2009
