No. At least they shouldn't. I don't know what kind of tech you might have.walt1227 wrote:Do they take the front bumper off to do the timing chain?
Welcome to the forum! Nice to see another master tech in here with (I presume) an M.Vapingmadmechanic wrote:Hey everybody, I'm an Infiniti Master Tech and can answer any questions you might have regarding this recall. Let me know.
I'd like to address a few things I see popping up in this thread...
First: If you had the original service bulletin done for the whining noise, you should not need to have the recall work performed. It's the same procedure and the same parts. They changed the way we get the parts though, instead of ordering separate chain guides and chains, they come as a kit for each side of the motor. It looks like a lot of parts, but that's because the engineers who designed the vehicle said that "x" part can't be changed without removing/replacing parts "y and z." So in order to do the repair job, we have to follow their rules or they will kick the claim and the dealer will be charged back the price of the repair.
Secondly: Please bear with us (the dealership service departments), there are a ton of these recalls out there to do and it takes one guy pretty much all day to do one of these, sometimes a little longer depending on what other work he has to do. My dealership usually has about 5 or 6 lined up ready to be done at all times and we have 6 technicians. You might think that we could get 5 done a day, but remember that our normal workload has not decreased, so we still have all of out other clients to take care of as well. We want you to have a loaner car to drive in the meantime and reduce the downtime of your car, so if we schedule your appointment for some point in the distant future, know that we are really trying to convienence you. IF your vehicle starts making that terrible whining noise on start-up please call your dealer and let them know. They will most likely bump your appointment up to get you in immediately.
Please remove any aftermarket parts it makes our job easier and gets your car back to you quicker. If you want any of the work from the bulletins that some have mentioned here done, expect to be told you will have to pay if your car is out of warranty. Any ECM reprogramming can be done under Emissions warranty (8yrs/80k), but don't walk in there with a printout and demand for this to be done. Even if you found it on the internet, just mention the symptoms that are listed in the bulletin and let the tech do his job. In all honesty, we dread when someone comes in with a stack of service bulletins printed out asking for a bunch of work to be done for free.
Let me know if you have any questions. I'm glad to help.
I can probably get you that by using a parts site online, however, will that tell you the software version? I would assume I have the same ECU (and thus part number) the car came with back in 2011...but the software may or may not be changed. Or do you mean I should unflash UpRev and go back to stock and see what part number UpRev sees? In that case, the ECM Part # UpRev shows is: 23710-1MP9E. When it's UpRev flashed, it reads: 23710-1MP9E-UpRev Flashed ECU.Vapingmadmechanic wrote:I cannot look that up by VIN, but if you can get me your ECM/TCM part numbers I can see if they are the most up to date versions.
Ahh, understood. Thank you!Vapingmadmechanic wrote:1MP9E is what I need. For some reason whenever the module is reprogrammed, it changes the "part number" even though the number on the physical part stays the same obviously. I will check that for you today.
As far as I can tell, 1MP9E is the most up-to-date software available.Ilya wrote:Ahh, understood. Thank you!Vapingmadmechanic wrote:1MP9E is what I need. For some reason whenever the module is reprogrammed, it changes the "part number" even though the number on the physical part stays the same obviously. I will check that for you today.
How do I check the TCM? Or is that one only able to be seen with a CONSULT?Vapingmadmechanic wrote:As far as I can tell, 1MP9E is the most up-to-date software available.Ilya wrote:
You will have to check that with CONSULT or possibly an advanced scan tool like a snap-on modis or similar.Ilya wrote:How do I check the TCM? Or is that one only able to be seen with a CONSULT?Vapingmadmechanic wrote:
Got it. Thanks.Vapingmadmechanic wrote:You will have to check that with CONSULT or possibly an advanced scan tool like a snap-on modis or similar.Ilya wrote:
I would still go back and complain. What's the worst that will happen? They'll deny it, which leaves you in the same boat you are in now. Best that can happen? Someone comes clean. You have nothing to lose.Dmix wrote:Ok so I got the car back today after they had it for exactly a month. They said they had to order parts cause things kept braking when they went on a road test. They replaced everything that broke for free so that's amazing. It drives GREAT now. Huge difference. There is a bit of a belt whine noise but the tech said that will go away after a few days. I'm happy with the car now and so glad I have it back. Only thing that really sucks is I didn't notice it till I got home but they hit the bottom of my passenger door and there is white paint on it and deep scratches. If I go tell them about it tomorrow I would imagine they would just deny it or say "it was fine when you left"
I will try cause after the $1300 bill I can't afford to fix it right now lolIlya wrote:I would still go back and complain. What's the worst that will happen? They'll deny it, which leaves you in the same boat you are in now. Best that can happen? Someone comes clean. You have nothing to lose.Dmix wrote:Ok so I got the car back today after they had it for exactly a month. They said they had to order parts cause things kept braking when they went on a road test. They replaced everything that broke for free so that's amazing. It drives GREAT now. Huge difference. There is a bit of a belt whine noise but the tech said that will go away after a few days. I'm happy with the car now and so glad I have it back. Only thing that really sucks is I didn't notice it till I got home but they hit the bottom of my passenger door and there is white paint on it and deep scratches. If I go tell them about it tomorrow I would imagine they would just deny it or say "it was fine when you left"
I had the water/sloshing sound which ended up being my AC I guess...but didn't have any issues with cooling.reggiebrown40 wrote:Regretting getting this done already. Infiniti had the car in the shop for 2 weeks. I took it on a trip up to Canada and there were no issues. I'm back home now and my hot/cold needle keeps jumping around. A sloshing water sound and thumping noise can be heard behind the dash. The timing belt didn't fix the low end torque issue for me. I still have to mash the pedal to get it to respond. Seems like some people here had it worse than others.
The list of successful timing chain repairs with no issues is shorter than the list of folks with issues after the repair, which, like you said is ridiculous. This has been a top-notch clusterf*&# from day one. I had an open ticket with Infiniti consumer affairs and they STILL could not repair my car correctly. I hate to say this but I'm going to be switching out of the Infiniti brand soon. I'm tired of the cost cutting, sluggish motors, dealers who can't fix things on the first try, etc. Me and my gf made a list and we found out that I have been back to the dealership immediately after a repair to fix the same issue 6 times in the last year.Ilya wrote:I had the water/sloshing sound which ended up being my AC I guess...but didn't have any issues with cooling.reggiebrown40 wrote:Regretting getting this done already. Infiniti had the car in the shop for 2 weeks. I took it on a trip up to Canada and there were no issues. I'm back home now and my hot/cold needle keeps jumping around. A sloshing water sound and thumping noise can be heard behind the dash. The timing belt didn't fix the low end torque issue for me. I still have to mash the pedal to get it to respond. Seems like some people here had it worse than others.
I do have the same low-end issue especially when giving very little throttle or pulling away from lights. Have to also give a lot more throttle than necessary to get it to shift down.
A few of us had issues with our cars after getting them back.
I don't want to talk about all Infiniti techs as I think the two on our forum are probably quite good at what they do, but Infiniti needs to step up their game...this hasn't just affected members using one dealership, there have been members from all over the US who've had post-work issues. Ridiculous.
Isn't that what Seafoam does? It's applied via the vacuum line as well. Come to think of it I haven't done it in a while...perhaps I can try again to see if it helps.Vapingmadmechanic wrote:Have you considered that your low end torque issues might be related to build up on the back of your intake valves? Have you ever seen what your intake valves look like? They all pretty much have 1/4"-3/8" of carbon baked on the backs of them. This is a design flaw with the 5.6L direct injection engines. The engineers kept a conventional PCV system where oil and oily vapors are sucked into the intake but there's no fuel spraying on the back of the intake valves to clean them like we used to have in muti-port fuel injection engines. The fuel now sprays directly into the combustion chamber and the oil builds up on the back of the valves. As the engine runs it gets baked on and becomes hard. Every direct injection engine I've seen with 15k or more on it looks like that. The good news is that it only builds up to a certain point due to the mechanical opening and closing of the valve. Once you give it a little more throttle, the VVEL kicks in and the valves open further thus allowing more air into the cylinder and providing the torque and power you expect. I would ask your dealer about a direct injection intake cleaning service. My dealer doesn't not offer one, but we are actively searching for a proven, effective product to offer as a service to our clients. It's basically a foaming spray that would be shot into the intake manifold through a vacuum line, allowed to spread and dissolve the build up, then the engine would be started and run to clean it out. Kind of like an Easy-Off oven cleaner. The problem with finding a product is that most are very caustic and finding one strong enough to dissolve the carbon without damaging the aluminum heads is a challenge. I'll try to find a picture in my phone of the intake valves on one of these engines.
What you need is something to sit and soften the build up. Basically oven cleaner. Seafoam is done with the engine running and I don't think it's strong enough for this. Hell, it might work. If done correctly it shouldn't hurt!Ilya wrote:Isn't that what Seafoam does? It's applied via the vacuum line as well. Come to think of it I haven't done it in a while...perhaps I can try again to see if it helps.
ECM/TCM updates have been done? Can you better describe "sluggish"? Does it just seems to bog down off idle? Is it just a hesistation? Does the engine rev up or drop during this? Does changing between ECO/STANDARD/SPORT mode make a difference?reggiebrown40 wrote:I bought this car with 26K miles on it, VApingmadmechanic. It's been sluggish since day one. Infiniti refuses to acknowledge this as being an issue. I doubt that carbon build up is the issue, especially since when you throw it in manual mode it accelerates just fine.
Well, it's sucked in while the engine is on but then you turn it off for 30-45 minutes and let it 'soak' to break up the sludge...whether it actually does or does not is another story. But, I usually do it every 30kmi and I'm at 82kmi now. Last time I did it was 10/19/15 at 65kmi. Might be worth a shot to do again.Vapingmadmechanic wrote:What you need is something to sit and soften the build up. Basically oven cleaner. Seafoam is done with the engine running and I don't think it's strong enough for this. Hell, it might work. If done correctly it shouldn't hurt!Ilya wrote:Isn't that what Seafoam does? It's applied via the vacuum line as well. Come to think of it I haven't done it in a while...perhaps I can try again to see if it helps.
I think Reggie and I are having similar issues, so he can corroborate my post, etc.Vapingmadmechanic wrote:
All updates have been done. As Ilya described -- from a stand still you can hear the car going through gears and when it gets to 3 or 4th gear it just loses power. You mash the pedal and it takes off. It's not just a hesitation, you can feel the loss of power. The engine rev does drop down as it's now probably in 4th gear. I always drive in sport mode. I usually manually shift because of this issue. I had a loaner Q70S awd 5.6 2 weeks ago and it was brand new and did the same thing, just not as bad.Vapingmadmechanic wrote:
Sounds a lot like the issues described in ITB11-008a and ITB12-021b.reggiebrown40 wrote:All updates have been done. As Ilya described -- from a stand still you can hear the car going through gears and when it gets to 3 or 4th gear it just loses power. You mash the pedal and it takes off. It's not just a hesitation, you can feel the loss of power. The engine rev does drop down as it's now probably in 4th gear. I always drive in sport mode. I usually manually shift because of this issue. I had a loaner Q70S awd 5.6 2 weeks ago and it was brand new and did the same thing, just not as bad.Vapingmadmechanic wrote:![]()
What is ITB11-008a? Quick Google search didn't return much. 021b I asked to have done (no idea if they did it or not though).Vapingmadmechanic wrote:Sounds a lot like the issues described in ITB11-008a and ITB12-021b.reggiebrown40 wrote:
If those have been done, I honestly don't know what else to tell you.
