Official 2011-13 M56/Q70 5.6L Timing Chain Recall Discussion
reggiebrown40
Car: 2018 Infiniti Q60 Red Sport
2011 Infiniti M56x - Dead
Dmix wrote:
reggiebrown40 wrote:
If you complained to corporate I think it's automatic that you'll get a survey. I actually have gotten 2 surveys for 2 separate incidents.
So the dealership refuses to repair my car and are now hanging up on me and ignoring me when I call and email. When I contacted corporate they said "sorry but this is an issue you need to resolve with the dealership". So now I either have to go through insurance or take the dealership to court. Haven't decided what route to take yet.
Dmix, what's wrong with your car? I think you mentioned something about the paint in an earlier post. Did corporate open a ticket and try to contact the dealer to resolve your issue?
Dmix
Car: 2011 M56X
2006 350Z GT (sold)
1995 240SX Zenki (sold)
Yes they scratched up the paint really bad across the whole right side of the car.
When I emailed corporate they replied once saying that it is an issue between the dealership and myself and they will not be getting involved.
reggiebrown40
sorry to hear that. I thought you said they had repaired the damage.
Dmix
Car: 2011 M56X
2006 350Z GT (sold)
reggiebrown40 wrote:sorry to hear that. I thought you said they had repaired the damage.
They said they fixed it but when I went through the car wash it rinsed away the crayon they used to "fix" it.
DredM56
Car: 2011 Infiniti M56 2004 Subaru Wrx STi
Lol the dealer I bought my M pulled that on me. It had a bit of a scuff on the front fender. They said they would have it buffed out and fixed. When I picked it up it looked immaculate. After 2 washes the rash was back. It's whatever I got a good deal on the car and got quoted 200 to take care of it and a couple other small blemishes.
In your case that's trash.
Flaco_taco
Car: 2007 m35x tech and 2005 fx35
Sorry if I didn't respond to any of you awhile back my phone got messed up , if any of you have any detailed questions on this recall shoot me a text
skov35
Car: 2003 G35
Will the recall fix the problem long-term, or is this engine's life suspect?
Consumer Reports still gives the M "much better than average" reliability scores, I wonder if that will change once they get wind of the recall and chain replacements.
What do you guys think this recall means for the used M56 Market?
Ilya
skov35 wrote:Will the recall fix the problem long-term, or is this engine's life suspect?
Welcome to the forum.
I believe they check a couple of things on the motor to see if they have been affected and are 'too big a gap' or something. If they are, then the whole motor gets replaced. If not, then only the chain stuff is done and everything should be fine going forward.
jd3rdcoast
Car: 2013 M56S, K&N AF, Stillen Catback, Sport Pkg, Tech Pkg.
Local dealer actually contacted me to schedule the service couple months ago for my 2013 M56S. Since I was having no symptoms I got the lead mechanic to go for an aggressive drive with me to impress on them that there was Zero issues prior to handing over for the job. I told him I want it back in same condition or better. Happy to report returned after 1 week with no issues now after 2 months. I have had no complaints for Clear Lake Infiniti over past 8 yrs dealing with them.
skov35
Car: 2003 G35
Should this deter anyone from picking up a used M56 if the work has already been done?
Ilya
skov35 wrote:Should this deter anyone from picking up a used M56 if the work has already been done?
Nope. I wouldn't worry about it as if anything went wrong it would go to the dealer for free to fix again.
Dmix
Car: 2011 M56X
2006 350Z GT (sold)
Lol wonderful update. My transmission lines blew and left me stranded on the highway. When the mechanic repaired it he said "whoever replaced your timing chain bent and banged up the lines causing them to blow" lol this Infiniti dealer is a joke.
Oh best part is it was -20°C and the tow truck service couldn't make it over till 7 hours later. While my 4 month old baby was with me. Thank god for Uber but still this has been one huge horrible Infiniti experience.
Ilya
Dmix wrote:Lol wonderful update. My transmission lines blew and left me stranded on the highway. When the mechanic repaired it he said "whoever replaced your timing chain bent and banged up the lines causing them to blow" lol this Infiniti dealer is a joke.
Wow. That's terrible. Guess I should be extra thankful that the service department (not so much sales) at my place is by and large pretty good. I feel bad for some of ya'll.
BlackCat81
Car: 2006 Infiniti M35x
2003 Lexus GX470
It's a permanent fix. It's a much beefier set of chains.
Doing chains on an M56 is a breeze, the oil pan doesn't even have to come off since the oil pump is chain driven. QX56's have an oil pump that's driven by the crankshaft, and the pump doesn't clear the oil pan to be able to get the chains off and on.
skov35
Car: 2003 G35
What about the lubrication issue, I thought there was something with the oil pumps not providing sufficient lubrication. Is that suspect at all?
BlackCat81
2003 Lexus GX470
skov35 wrote:What about the lubrication issue, I thought there was something with the oil pumps not providing sufficient lubrication. Is that suspect at all?
Not that I've seen, unless you're referring to the noise that comes when the chains stretch. The pass side chain comes in contact with the metal oil jet, rubbing a large gash in it. If that's the case, the oil jet is replaced during the recall.
spmcpa
Car: 2012 M56 and 2012 EX35
A question preferably for either Blackcat81 or VapingMadMechanic, an item that I have not seen clearly addressed yet in this thread. I have seen suggestions that most or all of the auto trans fluid may be replaced in conjunction with the repairs for the timing chain campaign.
Is that only for the AWD versions of the M56? In other words, if the vehicle is a 2WD M56 is it pretty much a given that the ATF will be changed out? Not at all likely that it will be changed out? Up to the tech's discretion that it will be changed out depending on his preference in executing the repair?
I ask because I sent my 2WD M56 in last week with instructions to perform the TC campaign repair and flush the trans. Mileage is exactly 50,000. The other local Infiniti dealer (now closed) only drained and refilled 3 quarts at the 40,000 mark.
I'm just curious if I should be paying for the auto trans flush (which I'll gladly do if appropriate) or whether it's not really needed because 75% or more of the fluid will be replaced anyways as part of the TC campaign.
Incidentally, this M56 had no engine or transmission driveability issues before being taken in for this service. Hoping it will return that way. Thanks for your input gentlemen.
Ilya
spmcpa wrote:A question preferably for either Blackcat81 or VapingMadMechanic, an item that I have not seen clearly addressed yet in this thread. I have seen suggestions that most or all of the auto trans fluid may be replaced in conjunction with the repairs for the timing chain campaign.
Welcome to the forum!
Unfortunately, both of those members only log in every few months. You may be better off PM'ing them. Or maybe someone else will be able to assist with this question. I think, generally speaking, the service department should be able to ask the tech who'd likely do the job...unless you're uncomfortable asking them?
spmcpa
Ilya
Is there a reason why you posted this twice, hours apart?
armybrat
Car: 2012 M56x with Tech Package (sold)
Custom 2-1/2" X-pipe exhaust with OEM sport mufflers
HPS intake hoses
Uprev tune
I ran into this situation with my '12 M56x. Last year, I had a 60,000 mile service performed, and had all of my fluids replaced. Around 400 miles after that, I threw a P0024 exhaust valve timing code error, and luckily I was able to make it to my dealership. At that time, the recall had just been issued, and they went ahead and took me in that day and gave me a new Q70L loaner. According to the FSM, on the AWD models, the front final drive assembly has to be removed, which involves replacing the transmission fluid. If you're going to have the timing chains replaced, I wouldn't have the transmission fluid changed. BTW, the FSM calls for the drain and fill procedure, not flush. I personally wouldn't recommend the flush. I've seen transmissions ruined because of this...just my $0.02.
In a nutshell, I wasted money on the 60K service because most of the cost was fluid changes...bad "timing" LOL
bigsurfing
Car: Infiniti M37 sport (2013).
So, my 2013 m37 sport just had a catastrophic failure over the weekend. No warning signs - I data log 24/7 off the obdid. No codes no check engine etc. heard a rattle and a minute later sounded like a rod went.
The car has 25k miles and maintained (i Co-founded mustangworld and been a race engineer in nascar and seen every kind of failure. From a new $70k tour motor tossing a rod into the pan on shake down lap 4 to you name it. Along with pioneering the first Dyno tuning software (injector pulse width to you name it)
Take any car - add forced induction of choice and injectors etc etc. wouldn’t be possible otherwise. And that wide band o2 is a requirement. But seen them blow up. Often due to pushing too much HP into a block and rotating assembly by made for the additional 300+ HP.
So the beauty. Infiniti without a tear down just denied the claim. Haha. Now I’m not worried about that end as legally they are on the wrong side, contractually and less putting it on a load bearing Dyno , draining all the fluids and blocking any air flow and running it at 750@rom at load for 3 hours .. maybe. (You be surprised).
Not to mention between myself, sister (who just did a national Nissan spot and dad. Easily 11 Infiniti’s (I’ve owned 44 cars in less year driving but I accounted for a Fx45 personally - rest mostly ford but Ben and benz in there too.
Yet to deny a claim on a 25k motor that was driven by a 71 year old man. (My dad gpassed in late 2016 (mom drives it now - and called me about the noise I went to check out and swap cars whilst I looked at it. So a well maintained car driven by 70 year olds to the store or UCLA hospital that year somehow caused the engine failure. It’s insulting to anyone’s intelligence.
Anyhow, not the 56 issue exactly bur similar. Never mind the transmission issues or that voice dial won’t recognize any digit over 6. Good luck dialing 911. Multiple visits no solution. They played games with the service description to thwart a lemon law Buy back. But it’ll be interesting. Got calls into the highest levels of corporate.
Just thought I’d note it. 0-failure in a day.
I’ll update the status as to Infiniti trying to weasel it of the warranty crate replacement. I just found it as egregious as anything I’ve seen in my many years in the auto world and racing.
Thanks
Ilya
bigsurfing wrote:
Fri Mar 02, 2018 12:51 am
Thanks
Yeah, Nissan's (Infiniti's) quality has TANKED. My dad's 2014 Pathfinder had the CVT crap itself at 4kmi. 4!
Keep us updated, wish you the best!
CurtisK
Car: 2011 m56X
Hi all,
Did anyone on this site ever get notified about the recall in Canada or had the service performed here? I have a 2011 M56 that's getting close to 100k on the odometer and starting to get concerned if it was ever done.
armybrat
HPS intake hoses
Uprev tune
CurtisK wrote:
Tue Aug 27, 2019 8:24 pm
Hi all,
I don't know about Canada, but here in the US, I believe the oil jet/timing chain recall campaign ended earlier this year. You can have the dealer run the VIN, or probably call Infiniti Corporate to see if your car had the work done. I bought my car used with 52k miles; I never received any letters about the campaign. I know sometimes the original owners will receive recall letters, but not the new owners. I've received recall letters for cars I've sold in the past, so I know it can happen. Anyway, the car started running rough on the way home from work one day, so I immediately went to my dealer. It pulled a P0024 DTC which was an exhaust valve timing control issue. Lucky for me, I was informed that this DTC was caused by a faulty timing chain, and that the repair would be covered under the new recall campaign. I was the first M56 in the Winston-Salem area to have this work done. This was in May 2016. Hopefully yours was done if the original owner received the letter and took care of it. I wouldn't have known about it if my car hadn't acted up when it did.
Yoda's Master
Car: 2012 M56
2009 370z
check your carfax. the carfax for my car showed the timing chain recall was performed.
91q45t
Car: 1991 Infiniti Q45T
How would one know if the timing chain has been done on thier vk56vd? Also does this apply to the hpfp as well?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
91q45t wrote:
Fri Apr 11, 2025 8:04 am
Visit a dealer with your VIN and they can print out the vehicle's service history and any open (not completed) recalls. If you want to post or PM your VIN, I can check it for you. The recall (P6305, ITB16-015) is no longer active, so if you were eligible but it wasn't done, you're SOL. As far as I can tell from old copies of the bulletin, it only applied to the chains and oil jets, with no effect on the HPFP or bucket.
