DAmn wit that mph u should be in the low 12s u sure u ran that time? And wat kind of tires were u using cuz if u were on regular street tires ur time is very hard to believe..... Oh and ur 60ft is not good either i dont kno but i call BS....wannaS13 wrote:89 coupe97 s13 Blacktopstock t25fmic3' exhaust from elbow backopen diff.ACT clutch****ty tiresmanual boost controller at 13 psi
r/t .28060ft...... 2.2371/8.....8.588mph....86.571000.....11.0481/4....13.118mph....109.40
That trap speed is a mid to high 12..... Ok so his 60ft sucks, but look at his 1/8th speed and time, they are very respectable. I don't call BS but, lets get those traps down some.... Compare his times with the guy above, he trapped in at 114 and ran a 12.95 with 2.3 60fts. He should be in the low to mid 12's given he can get traction....VSJA1725 wrote:DAmn wit that mph u should be in the low 12s u sure u ran that time? And wat kind of tires were u using cuz if u were on regular street tires ur time is very hard to believe..... Oh and ur 60ft is not good either i dont kno but i call BS....
He didnt own anyone its just very hard to believe he ran that time without any tires and on 13psi... Gratz to u and i take back wat i said i will post mine as soon as i get some batterys for my cam.jr_ss wrote:
PWNED....
1st off that trap speed should put him in the low 12s easy(friend of mine ran 12.8 at 103... i have the timslip). Yea his 60ft is no good but his 1/8 speed and time are all higher then mine. Also we cant compare it to the guy above him cuz the other guy had an upgraded turbo and he ran on strreet tire with full pressure his time seem very believable. Im sry but i seen s13 and s14 wit my setup and the setup the person in question has run high 13s if lucky wit regular street tires soooo idk its wateva im just stating that its very hard to believe.jr_ss wrote: That trap speed is a mid to high 12..... Ok so his 60ft sucks, but look at his 1/8th speed and time, they are very respectable. I don't call BS but, lets get those traps down some.... Compare his times with the guy above, he trapped in at 114 and ran a 12.95 with 2.3 60fts. He should be in the low to mid 12's given he can get traction....
Relax dont get angry lol. Im just saying its hard to believe but gratz on the time hope u run lower times soon.wannaS13 wrote:i dont know what else you need for me to prove this ****...i mean honestly i showed a time slip i also have two other slips one where i ran a 14.1 @ 105mph missing third completely and another at 14.7 at a 106 but on that one i launched to high and spun 1st 2nd and bogged 3rd.PIR is a very fast track and i mean it was getting cold out so think whatever the hell you want
Your track times are right but not for your setup. Trapping 109mph with a T25 is a first to me. The normal for the T25 is 106mph @ 14-15psi. Your Trap Speed is more of a 280-300whp car. Definitly seems like you have a much larger turbo. You positive you have a T25?wannaS13 wrote:89 coupe97 s13 Blacktopstock t25fmic3' exhaust from elbow backopen diff.ACT clutch****ty tiresmanual boost controller at 13 psi
wow...thats not good... cause my 6000lb F150 ran a 10.6 on the 1/8... u ran a 10.. no offense or nething... im sure youll do a helluva lot better with slickshpmachine wrote:one of the crappiest/craziest slips you'll ever see! can you say "no slicks"??!!sr redtop t4 turbo jwt ecu740s15psi
