To answer the first question the starter is engaging, the cams are moving while cranking, along with all 6 coils firing in proper sequence along with the injectors.Darius wrote:Do you have the lifter lash adjusted/shimmed properly? The valves could seat fine, but if the lash is off, they will stick out. I agree with you that it is probably the valves leaking. When you did the leakdown, was it the intake or exhaust valves leaking? Was it consistent or one or the other or both??
Who did the head assembly? If the shop did it, I would go chew the owner's a$$. If you assembled it yourself, I would double check the valve lash first. I don't think a valve job could be that botched to cause zero compression reading.
Did you count the teeth marks in the belt between the tick marks on the cam gears to make 100% sure that it is timed right?
rb25 head/block , rb26 crank: rods and pistons. Stock Hydro lifters that I just rebuild, all are like new.DriftingisLame wrote:Is this an rb26 or rb25 head? If its an rb25 head, do you have some tomei solid lifters or something?
That is what I thought too, apparently there is more? If not I don't understand what would be causing them to leak....DriftingisLame wrote:Those lifters are called "hydraulic lash adjusters" for a reason. You do not need to adjust them.
I've probably swapped cams 6 times on my motor. I've never adjusted lash. I believe I confirmed it the first time in the FSM, but it was a couple years ago.
They hot tanked it so I think they might have. I know for sure the 6 cylinder all valves were removed..... Lash adjusters are where exactly?Coolwhip wrote:the lash adjusters can only adjust to a certain range.
Did they do a valve job? Or disassemble the head? (maybe you covered it in a previous post)
No I was leaving it to the professionals to insure matters such as whats currently happening WOULDN'T...Coolwhip wrote:So they disassembled the motor and reassembled it?
Or did you have a par-take in the festivities?
Indeed, smells so fishy in fact that it seems like this has to be something really simple. Think about it. The bottom end is really really hard to get wrong, so at the very least, you wont have to remove the motor again. Worst case scenario, you'll have to remove the head.Coolwhip wrote:smells fishy
Exactly, even If I didn't have lifters in the head...Coolwhip wrote:i think his leak down test determined the valvetrain. And eliminated the rings from the problem.
But if the lifters are calapsed as in not blead, they would make a whole bunch of noise but still create compression.
Must be with either the seat of the valve, or the lash clearance. If there is not enough the cam center lobe will slightly push down on the valve creating a leak when "suppose to be closed" position.
smells fishy
prime? Didn't think we could even do that with our engines due to the oil pump configuration, I poured oil in both valve covers before I capped them. Thats about as much priming as I did.Coolwhip wrote:did you prime the oil system?
They sould of turned the engine to build compression before ever even giving it back to you the customer.
I could stop at my garage later after work and give it a try see if I can build some pressure. I hate the sound of my motor turning over now, it doesnt even sound like an engine, just an electric motor spinning with no load lol.Coolwhip wrote:pulling fuel and spark, and turn key for a few seconds about 15sec, and then stop, and repeat the process over and over for like 2mins, to build proper oil pressure before anything starts spinning fast.
Dropping some oil into the oil fiter. Wetting the head with some oil. etc.
lol, that was my first thought when I hit the key for the first time. It is in fact turning the WHOLE motor over....Coolwhip wrote:the starter is in FACT turning the flywheel? As in harmonic balancer and cams are turning when the key is turned?
I wonder if they forgot to torque the head down, :/ that would be ****ty
