Carl H wrote:pull the plugs out, it should build pressure with a hurry.
Didnt work... I tired for a few minutes... and nothing....
It actually turns out our master mechanic Cory is a ****ing idiot.... who enjoys rebuilding his lifters only to install the internal lifter body backasswards!!
So after removing all my **** in front of my rad support, removing my belt, cams and all that other garbage, I did a leak down test with no cams all are good, actually strong enough to turn the motor over, and actually almost knock my car off the jackstands (it was in gear)..... So I stayed motivated and reinstalled all my ****, got it bare bones enough to attempt a start...
I go to crank, it cranks and cranks sounds like a car this time but no startsty... I glance down at the floor to notice I had disconnected my ignition box, plug her in, crank and a ****ing roar echos through my closed garage as I was graced with the presence of graduating from the NRRB association...
Omg you have no idea how ****ing good it felt, the car ran, idled, reved, one down side was the obnoxious lifter tick since they all got squishy from no oil pressure.... I let her run for about 45 seconds , watching my gauges as oil pressure built up to around 60-70 and shut her down since the rad isn't hooked up... wow does she sound mean as hell.
Hopefully nothing else goes wrong, and the lifters re-pressurize after idling for a bit, and a weekend drive might be in my future? Then to the dyno to hopefully lay down some good numbers.
thank you all for the suggestions and intuition into figuring out my retard problems!
