xjon wrote:Lag and drag.
S13GUY wrote:I don’t like it for the following reason(s):
Let’s say for example my car, a 240sx, has a ka24de (slow pos stock), intake and headers and a big coffee can muffler. No let’s say I want to go up against an all stock sr20det. My 240sx will need about 150 shot of nitrous to beat it. Now let’s say I win and I kill the sr with the aid of nitrous. Sure I beat it, but I was only that fast for that short amount of time. I am not always that fast. I can only beat the sr20det w/ a 150 shot of nitrous otherwise ill get burned.Another reason I don’t like it is because it’s the easy/kiddies path to more hp. Id like to tune the car to xxx hp rather than take the easy way and just have xx hp for a short race. Another reason I don’t like it is because ppl are trying to use it in touge racing. seriously these ppl are dumb asses Oo I just remembered a rice quote about that!!!![]()
xjon wrote:J-spec tuner- What you have is a well matched system, the "proper equipment" as you say. You're low-end power would be the same if you would unbolt your turbo and run your engine as a NA. It is your mid/high-end that the turbo helps, correct?(ofcourse that depends on your equipment size) So to say one has 100% turbo power from the get-go would be false.
xjon wrote:jspec- you still can't say it's instant-on. Yes 100% boost at 4k but to get to 4k is another thing. what's going on at 3k, turbo spooling, compressing air just starting to fill the pipes. It's not even in the manifold yet. Some, but not all.
Aries wrote:any of you doubters...I will gladly put a sprayed KA car up against any of your SR or turbo cars in the straits or the twisties if you'd like proof that nitrous can do more than go in a straight line.
But, Alan is correct, sanctioned racing events other than drag racing do not allow the use of nitrous.
xjon wrote:
Such as 95ka24de- He doesn't like the fact that he spent more time and work on his car and still get beat by a stock car with only N20 on board. I can understand the frustration in that. That would just make me work more on my car.
