Northern NJ drift/drive club
Including VA, WV, MD, DE, DC, NJ, PA, CT, RI, NY, MA, NH, VT, and ME
Samurai C
Car: 92 Nissan 240SX KA24DET
ya my girl gose to bergen and she said she saw a red hatch me and miro were talking about your rims just a min ago i stopped by him to get my steelies he is coming along nice with his hatch
BMAR240SX
Car: 1993 Nissan 240S Coupe
PyroTecK wrote:oh while im here being slightly useless... bmar idk what ur budget is or how bad ur towers are (hint: post pix) but they do make them new, im thinking about going this route for my coupe.
You are out of your mind lol.
I have rust on the edges of 3 where it meets the strut tower
I would take pictures but a buddy of mine said its bad luck unless im going to fix it lol. I was thinking the job would range me for both sides 100-200 bucks for both sides on how miro did it.
My coils are coming this week and i am pretty cautios about installing them with that rust on the tower i scrape it off it wasnt bad just i hit it to hard and the screw driver went through roflmao meaning the metal is weak and needs to be reinforced, so i might have to hold on a bit or just install the coils and garage the car
PyroTecK
Car: 1993 240sx SE 5speed fb
hehe my sister goes to bergen... but i was there a few weeks ago speeding up and down the parking lot for like 20 min picking her up though lol
BMAR240SX wrote: You are out of your mind lol.
i dont think i know a person that would argue w/ u on that lol surprisingly the top part of my towers isnt that bad on the blue car, the red car has a lil something something here and there but ill be working on clearing that out. i got so much work to do on both of them... but i talked to a few people today and it seems like the matter is decided... my coupe is getting new towers, might get them blingified, deff reinforced and stitched courtesy of ATX and a assload of cash.
i wish i could work on my car like miro is but sadly my work depends on my car right now... so thats y im getting the coupe done as a daily... once i slap the 30r on the ka in that red car im gonna want the chassis to hold up and the wheels are pretty dope, got a great deal on them too w/ pretty fresh tires... and they look pimp on both cars lol
[/whoring]
BMAR240SX
I know, im going to see what i do hopefully i get it taken care of before i slap the coils on. My rust is not that bad so i am going to get it taken care of before it becomes worse
Samurai C
lol nice i picked my girl up once and i was doin the same thing needless to say im not allowed to pick her up anymore hahahaha
nice lip kit i was looking at that one but i didnt know how it was gonna look on my car
PyroTecK
it looks great... i think that and the hotnakedasians sticker are the only things i get compliments on, and its not even put on well. i kinda just slapped it on one day. fitment is ok i guess... could use a lil work w/ a dremel here and there but its fine for now ( i cracked the sht out of it at the paramus nissan meet and still havent fixed it)
seriously ive had people wave me down and ask me to pull over just to ask me about it lol
B-Boy DuB-L
Car: 1993 Nissan 240SX
I dont know wtf Is wrong with my car. I did a compression test today and i got 170 across all four, and i thought it was the head gasket. The wierd thing is last year all four were around 150. But i'm thinking maybe this Bar's leak stuff i used actually worked. I tried it on thanksgiving and i havent drove my car since then cuz it still overheated, but today it didnt. Maybe it needed to dry lol idk.But then my car never overheated until like10 minutes or less of driving, and i still have white smoke. The coolant also looks alil milky, but it could be from the headgasket stuff? Sam, Miro, anyone. Should i just replace with a new head gasket or wait and see what happens
B-Boy DuB-L
I'm so frustrated!!!!!
Samurai C
well if you oil is getting milky you gonna do bearing damage soon any clean plugs? the white smoke is a dead give away that the head gasket is leaking coolant into the combustion chamber but the semi good compression is weird pour 2 caps of a quart of oil into the cylinder and do the test again if the reading is higher you rings are bad and junk the engine if its the same than it might be leaking into the cooling system pump shop air into the cylinder when its at TDC and see were you hear the air coming out look for bubbles in the cooling system if the rings are good and you go ahead with the headgasket do a timing chain kit and take the head to get rebuilt and do a water pump and flush the cooling system and engine good and do valve seals get a head kit from felt pro i only trust them and get new head bolts and if you have any other questions just ask lol good luck
Samurai C
kool if i see you im gonna run you off the road and come running up and scream nice lip in you face than steal it with your pimp rims lol J/K looks sexy
Miro i better open my shop soon lol i need to get you guys rolling
LDR opening soon!!!!!!!!!!!!!!!!
(i wish)
B-Boy DuB-L
well the oil is not milky at all. The plugs are clean which is why i thought of head gasket. But then again when i overheat i lose coolant. ok im gunna try with the oil first thing in the morning.
Thanks Sam
mirochuki13
Car: 1992 Nissan 240SX Hatch
1. Make sure you have all the air out of the cooling system. Raise the front of the car (so bubbles go up to the rad), put a large funnel in the rad, fill the funnel halfway, turn on the car and let it run for like 15 minutes (rev the engine once in a while). There should be no bubbles coming out after a while. If there are, then something is wrong. If no bubbles, it shouldn't be overheating anymore.
2. What does the exhaust smell like? Antifreeze out of the exhaust has a pretty distinct smell.
3. Is there white smoke all the time? It's normal to have white smoke while the car is warming up. Water that condensed in the exhaust/cat is evaporating while the car is heating up.
4. Take it to a shop and tell them that you think your HG is blown. Unless they're total bastards, they'll probably take a quick look at it for free.
5. Sell your car, and put the money towards something that doesn't need so much work (like an S14).
http://www.clubloose.com/clubl...=2171
Seriously. Get it. This is an awesome deal.
B-Boy DuB-L
Miro i would if i had money, But im broke=(
Sam i put acap and half full of oil into one of the cylinders. It raised the compression by 10 psi. I know that means rings but if the rings are holding 170 psi they cant be that bad. And that shouldnt be the reason y i'm overheating and losing coolant without any leaking. The car runs perfect for like 10 minutes then overheats. There is no wierd noise either. I'm stumped as fcuk
mirochuki13
Install turbo. Problem solved.
B-Boy DuB-L
ok hahah I need a serious answer
PyroTecK
prob beating it to death but bleed the sht really good... when i swapped my rad i had the car running w/ the bleeder screw out for like an hr and tiny boubles kept coming out... it finally stoped and i havent had any issues ever since... i thought i had bled it good the first time... then the car overheated and i scared the sht out of myself... got up to like 220 degrees on the consult since i dont have a gauge... the dash one was up in the red pretty bad... but like i said... bled it for an hr and no problems since.
and the smell of the smoke is very important too. ive smelled a ka w/ a blown headgasket and u can immediatly smell the coolant. however marcs been having a problem w/ his car blowing whitish smoke and it seems like its fuel... deff doesnt smell like coolant and i dont think hes losing any coolant either. i think something w/ his fpr. my car it blows smoke if i idle for a while and rev it a lil... one of the perks of not having a cat i guess.
if u do have a blow headgasket, ARPs and felpro all the cool kids are doing it
mirochuki13 wrote:Install turbo. Problem solved.
the man speaks the truth
the lip has been put on snowplow duty today
mirochuki13
PyroTecK wrote:the lip has been put on snowplow duty today
ROFL
Samurai C
i put new snow tires on my nice new steelies thanks miro i should be out drifting but im sick as a dog it sucks i took my girls truck to the store last night and i saw a 350z and a evo pull around to the back i knew what they were doin lol
mirochuki13
Samurai C wrote:i saw a 350z and a evo pull around to the back i knew what they were doin lol
Either sliding or gay sex...
Samurai C
well ya i guess you could slide behind the building i didnt think of that lol
BMAR240SX
PyroTecK wrote:
Wow lol i haven't even moved my car from this one where it doesn't recieve as much snow cause its sort of protected, i just clean it and warm it up and pray the snow stops
Samurai C
thanks again miro
mirochuki13
Nice Sam. So sleeper... haha.
Was driving my girlfriend home last night in the Durango:Her: Wow, you've gotten a lot better at drifting.Me: How have I gotten better?Her: I'm not scared anymore.ahaha
BMAR, I talked to Dat about fixing your strut towers. He's willing to do it, and he's a better welder than I am, so it'll come out nice. Just give him a call (973-477-5989), and work out a price.
Samurai C
Lmao durango drifts I drifted my sisters cavalier a little bit ago she was screaming ha ha ha I was out today messing with my car its cool when you park on snow and your tires are still smoking
BMAR240SX
I wish i could do that sounds like fun man
Thanks Miro i will give em a call,but who is Dat? lol
mirochuki13
He posts here once in a while, used to rent the garage with me.
B-Boy DuB-L
Wait you rent the garage by yourself now?
BMAR240SX
mirochuki13 wrote:He posts here once in a while, used to rent the garage with me.
Thanks bro i spoke to him, things looking good I hopefully will be taking care of it soon
ldatstarl
Car: s13 then AE86 then MX5
My New Baby
ldatstarl
just some welding pics
lol just showing off my skills jkjk
Return to “Northeast Region”
