parks99 wrote:Hi ErMasta,ErMasta wrote:Well I am new here but read all the pages on the Rogue lol.
Anywho, You only have to take of the bottom of the gate trim. You really dont need to take off hte top or side trims. Now here where you have to make a decision....Either you do what Parks69 and myself did ( open a hole by the perforated square on the gate trim cargo light is $24.00 and you cant even noticed that it does not belong unless you stare at it or...
Spend 135.00 US for a gate trim that brings the hole for the cargo light and buy the cargo light assembly. You will be looking at about $160.00 for the whole thing.
By the way i did find another unused electrical connection near the cargo plug...wonder what that is for...maybe for the rear camera? I believe that our 2010 Rogues are pre wired for all the extras, but i could be wrong.
Next stop for me will be the vanity visors..cant seem to find them cheap tho.
Are you saying you installed your light without the trim? Do you have a part number for the cargo light trim? Also, if you find those vanity mirrors cheap let me know. I picked up a cheap mirror from walmart, but it is already digging into the roof material. I wish they would of included some of these little things. I test drove a sl first, but thought I was only giving up the premium radio when going to the s360. Want to do the fog lights also, looks like they are pre-wired too.
Hello Parks,
Sorry if i did not make it clear.....Read below: I got this from Semitone a few posts before ours.
We have a 2010 S 360 that did not have a cargo light. Imagine our surprise when loading groceries for the first time at night. Nissan could not have been serious.
However, pulling out the lift gate trim revealed a pre-wired connection for the light. I simply ordered the OEM light and plugged it right in. Here are the steps:
Order the Luggage Room Courtesy Lamp (P/N 26490-CA000). You need !!
Pull the trim from the top of the lift gate. You dont need to do
Remove the pillar trim. Dont need to doRemove the plastic fasteners form the bottom of the gate.
Carefully remove the gate trim panel. This is what i call the bottom gate panel( its easy to take off.You should notice the light socket taped to the harness on the drivers side of the gate.
On the drivers side of the gate trim panel, you should see a perforation for the OEM light. This should be in the approximate location of the light socket.
You'll have to cut a hole in the panel for the light to "snap in" snuggly. I'll leave that to your imagination. Just be careful not to cut the hole too big or the light wont hold.
In the "ON" position, the light acts just like the OEM, turning on when the gate is opened and off when it's closed. Looks like it belongs.
Look for what i highlithed for you.
Now look at the pics some members have posted. You will find that the light will sit flushed to the gate trim...Our will not be flushed since we have to cut the gate trim for the light to sit on top of it.
Once you get the cargo light..flip it and look at the bottom of it. You will have to cut a small hole for the light to fit but make sure is not to big or the light will fall inside the trim.
I found the visor but they want way too much for them and the fogs i found but i need to make sure they bring all the brackets.
