(FOR ANYONE THINKING OF DOING THIS, YOU OBVIOSLY WONT HAVE TO PUTZ WITH THE LED MODULE LIKE I DID. JUST HEAD OVER TO ANY LED SUPPLY ONLINE STORE, http://www.oznium.com IS A STORE I HAVE ORDERED FROM. GREAT CONVENIENT MODULES. http://www.superbrightleds.com also comes to mind, as i know a lot of the maxima guys ordered speedometer led's from this site. i Never ordered from here, but they have good reviews and cool 12volt LED modules.)
The install was pretty simple. i removed the plastic cover on the inside of the lift gate:
two plastic push rivet style fasteners by the bottom of the lid near the handle insert
after that, just grab the plastic lid and tug... HARD!
Next i found the back of the lighting lamp already there.
Blue Wire = Ground(negative)
Yellow Wire = Postive
take your LED light module and just solder the connected to the wires, or use quick snap wire splice, etc.
i just soldered for a solid connection and used heat shrink tubing to give everything a clean connection.
i drilled some tiny holes behind the LED module to run the wires, for a clean install.
i attached the module with 2 aluminum pop rivets.
i attached the module to the center hump pointing towards the ground, bumper area to give me plenty light where my feet will be.
HERE IS A PHOTO OF THE LED LIGHT COMPARED TO THE STOCK REGULAR LIGHT:
I A GOING TO ADD MORE NOW THAT THE WIRING IS THERE, I AM THINKING OF THESE:
http://www.oznium.com/prewired-superflux
