No Frills/Custom Exhaust Thread
dickie
Car: Killer Turtle
Mikoriad
Car: 93 240sx fastback
I saw sombody mention the obx path.... Well, I took it with great results. I bought a 3" OBX can off ebay for 80 bucks. Then had a little shop put a generic 3" cat on with 3" pipping all the way back to the OBX. So the total spent was 120 bucks for everything. That was just about a year ago, and have no signs of rust, sagging leaks or looseness. Now for the sound... It's very similar to a WRX with an exhaust at idle and normal acceleration, then turns into this wild burbling roar at WOT (not at all buzzy). From about 4k and up it's race car like, and off throttle engine braking is wonderful. Bottom line, if you drive right it's fairly quiet. One downside is during long highway journeys the rumble get's a little annoying.
A34D4ME
Car: 89 coup
Mikoriad, is your car N/A? Do you have a resonator?
cwalke32477
Car: 1989 Nissan 240sx
Will my car be better of with a 2.5" or a 3" exhaust system? It is a N/A ka24E engine bone stock. Anyone know where to find dyno results for a 2.5" and a 3" exhaust?
InsanityInc
3" is superior.
http://forums.freshalloy.com/u...art=1
Compared to
zerothread?id=147604
Clearly, the 3" is superior.
pr240sx
Next time I change my exhaust. will use a 4 dia. pie with a pipe heaterJust to keep the gas flowing fast and hot!
A34D4ME
Car: 89 coup
I wonder what would happen if someone tested the same car with the exact same setups except for size. That would be a valid test.
Anybody know of someone who's done this?
InsanityInc
A34D4ME wrote:I wonder what would happen if someone tested the same car with the exact same setups except for size. That would be a valid test.
They both have the same mods besides the exhaust (an intake). The test is perfectly valid, just admit that you're wrong. It's not like one of the dyno graphs is all screwed up indicating a problem with either engine or something.
Edub1
Car: 89 240sx KA-T
A valid test can only have one variable. Two different cars could behave differently even with the exact same exhaust system. Plus subtle changes like a couple of tight bends or a bad muffler choice can have a big effect.
Even if we assume that a 3" flows better, it would stand to reason that we could expect diminishing returns. Something like the first 12HP when going from stock to 2.5" and maybe an additional 2-3HP when we jump from 2.5 to 3". That's just the way things ussually work, it's not a garantee.
But I'm wondering, InsanityInc. You seem to know an awfull lot about a number of complex subjects. Would you mind sharing with us your educational background? Are you an engineer or an engineering student?Are you in college? What year?
YRUSOSLO
Car: '89 240 hatch
Exactly what I did - well minus the 3" and OBX but still the purpose of this thread was - no frills
I'm glad that worked out for you. Despite Insanes rudeness I still pay attention to what he says because he does have some intelligence and I'm not going to argue with him about what he knows.
Edub1
Car: 89 240sx KA-T
YRUSOSLO wrote:Exactly what I did - well minus the 3" and OBX but still the purpose of this thread was - no frills
Who are you talking too? What did you do?
Silvia_Freak
Car: 1992 NIssan 240Sx KA24DE
I have a HKS nock-off. Are there anyway to duplicate a header sound or cat. sound. ANy mufflers sound like that. I want something loud. and not ricey. BUT annyoning.
YRUSOSLO
Car: '89 240 hatch
Edub, Notice at the top of my post where it says re: (Mikoriad)
Also somewhere on pg1 or 2 I explained my el cheapo setup. Basically that is what the thread was looking for not is "2.5" better than 3" " or "what is the best muffler out there".
Now notice the top of this post will read re: (Edub) I still wish I knew how to quote certain things instead of complete posts.
Edub1
Car: 89 240sx KA-T
You know I always forget about that.
If you want to quote just one piece, just use "quote" and delete the portions you don't want. Just don't delete the [quote] business at either end.
I agree about the diameter business. It would be nice to see a true comparison. Maybe someone with a good 2.5" will post some good numbers.
YRUSOSLO
Car: '89 240 hatch
Edub, I love your sig. that's me exactly! You are a Libertarian do some research if you don't know about them. Check out Boortz.com
Edub1
Car: 89 240sx KA-T
YRUSOSLO wrote:Edub, I love your sig. that's me exactly! You are a Libertarian do some research if you don't know about them. Check out Boortz.com
I have. A lot of Libertarians have some pretty extreme ideas. I'm more of an independant, one issue at a time kind of guy.
Edub1
Car: 89 240sx KA-T
Suddenly it got awfully quiet in here - was it something I said?
Mikoriad
A34D4ME wrote:Mikoriad, is your car N/A? Do you have a resonator?
Yes sir, it's definitly n/a.... for now and no resonator. I only have the OBX can on the back.
sidewards
Car: 95' 240sx sr'd, 00' Sierra 1500, 94' cbr600 'fighter
What if I have a local hillbilly muffler shop put a flowmaster 40series on my stock exhaust system? would it be worth $100?
Edub1
Car: 89 240sx KA-T
Hell no, our cats are the old super restrictive honey comb design. The biggest advantage is going to be a free flow cat or test pipe followed by bigger pipe and a decent stright through muffler.
sidewards
will a highflow cat set off my o2 sensor. I have a 96 so it is obdII.
eddiec
Car: 91 S13
it shouldn't. the second o2 only looks to see if there is any difference from the first o2 reading. and even the crapiest cat can catalze enough gas to keep it from getting an improper reading.
Edub1
Car: 89 240sx KA-T
I think in the SOHC it's before the cat, not sure about the DOHC.
Neejay
Edub1 wrote:I think in the SOHC it's before the cat, not sure about the DOHC.
Yeah, its before the cat on a SOHC.
And I spent an assload on my exhuast by not doing it right the first time. But I basically have a magnaflow 2.5" hi-flow cat, 2.5" magnaflow resonator, tanabe muffler. All 2.5" stainless steel, mandrel bent piping. Sounds nice, not too loud, not too quiet, but perfect outside/inside. I get a lot of compliments on it when people hear it outside and inside the cabin.
If I decide to scrap it, or get another 240 down the line, I'll probably go with BRM dual-tips.
InsanityInc
Edub1 wrote:A valid test can only have one variable. Two different cars could behave differently even with the exact same exhaust system. Plus subtle changes like a couple of tight bends or a bad muffler choice can have a big effect.
The 3" we're assuming obviously doesn't have anything bad about it, since it's the higher performing one. The 2.5" one has pictures to show it wasn't a POS, and I believe it was a BRM, which uses magnaflow straight-through perforated core mufflers.
Quote »Even if we assume that a 3" flows better, it would stand to reason that we could expect diminishing returns. Something like the first 12HP when going from stock to 2.5" and maybe an additional 2-3HP when we jump from 2.5 to 3". That's just the way things ussually work, it's not a garantee.[/quote]Yeah, at some point something will be worse, but nobody's really tested what that point is.
Quote »But I'm wondering, InsanityInc. You seem to know an awfull lot about a number of complex subjects. Would you mind sharing with us your educational background? Are you an engineer or an engineering student?Are you in college? What year?[/quote]I'm a software engineer. May not sound like much when it comes to cars, but I actually had to take an assload of physics and chemistry simply because software engineering is still considered an engineering degree. Beyond that, I had a minor in automotive engineering anyway. No degree for automotive, but I could probably take a few 300 level classes and get one.
And the reason I didn't respond to this earlier is that I haven't responded to anything in a few days. Search for posts by me if you don't believe me.
A34D4ME
Car: 89 coup
I see, Software engineer - you ought to drop in on the guys over on hybridka.com and help them out with some tuning issues.
What area of software engineering are you involved in?
InsanityInc
A34D4ME wrote:I see, Software engineer - you ought to drop in on the guys over on hybridka.com and help them out with some tuning issues.
Really depends on what kind of problems they're having. The engineering aspect of the ECU/chipsets is generally out of the way, unless they're having some problem where they need an entirely new management system that utilizes a better/more precise map system or something.
And I'm not sure what you mean by "area". Currently I'm working for a company developing Information Visualization technology, if that's what you mean.
HKSdrift3r
well staying on the topic of cheap exhausts.. when i had my DSM I ordered a tubing kit from VRS exhaust and a Dynomax Ultraflo muffler from Advanced. I only paid 225 for the entire 3" setup and welded it with my friend. check out vrsexhaust.com as they do have the Tubing Kits for 240's as well. Only took a week for them to get it to my house. Great company!!
Edub1
Car: 89 240sx KA-T
How do you like it? Looks like I'm going turbo again so I'm wondering what I'll even need for a muffler.
HKSdrift3r
Well like with all turbo cars, the exhaust will never sound ricey at all. The ultraflo muffler sounded deep, throaty, and wasnt obnoxiously loud. The price at Advanced was great, $75, compared to $110 + S/H at Jegs/ Summit. I also had a VRS downpipe and it was of superior quality. It had nice welds (compared to mine) and also had a flexpipe that eliminated vibration. VRS exhaust is a great source for DYI guys. Check 'em out!
