Nitrous 1/4 mile times
Asleep Altima
Car: Turbo Altima, SR'd S13
you arm it from the get-go but you dont spray until the 3 grand in 2nd and all the way thru 3rd and 4th if you get that far. you also dont want to spray under 3 grand in any gear. ill say, low 15's maybe high 14's. rwd should be a little easier to launch, but until you get used to it, those are the times im throwing out. good luck.
crazy2002mexican
Car: Racing, Paintball
i have yet to go to the track but i did get my flywheel and clutch in this week and it did make a big difference. my friend in his spec v runs a 14.8 and he just put a header on so it should even be faster. But none the less from a stop i can take him all the way till about 95-100 from any other roll we are side by side till 90+. He used to walk me like nothing. So i should......be in the 14's all motor :)
Asleep Altima
im still saying, maybe, but wont happen. not being pessimistic about it, i want you to hit it, just being realistic. :)
crazy2002mexican
lol bfg drag radials?? i mean come on .... have a little ka faith my **** is running good and plenty strong
uno
in my 93 coupe, i ran a 9.5 1/8th on my 70 shot and the nitrous solenoid burned out in the middle of second gear and the car started studdering so i'm sure i coulda had a low 9 or high 8. I had a 2.0 60Ft time on Kumho Mud+Snow tires. I haven't ran the 1/4 with it yet, waiting on the nitrous solenoid and some new tires.Other mods are short ram, asp udp, and hks hiper catback.
crazy2002mexican
im talking all motor 1st then im going with a 75 shot..and looking @ some peoples times with 4.60 gears looks like i need those also
240sxOwner
Car: 93 240sx
I ran a 15.5 with just my gears, and i had some crappy 205 tires...launched at about 3K....I ran a 9.98 1/8 i think it was, i am looking for another KA cuz mine is all messed up with the timing, so i will have some updated times with the nitrous in a few weeks or so.
crazy2002mexican
x-nay on the 4.60 gears....looks like j30 if i can get a hold of it
Projex240
Car: Dogs , My RIDE
13.9 witha 75 shot and other mods. at 100 mph exactly on 110 race gas. This was with an open diff too--now im going back with the jwt ecu and the lsd.maybe less time? Im also considering running this time with slick.
240sxOwner
Car: 93 240sx
What "other mods"...stock internals? What was your timing set at with the 110 race gas...
Projex240
Car: Dogs , My RIDE
the base timing was stock, and the jwt ecu does its thing. I didnt adjust teh timing due to the fact i wouldnt detonate on 110.Other mods. i/h/e stock ignition, etc. I have a act clutch too, and 370cc injectors (my jwt is programmed for them)It was a good run. Im looking to better it soon. But im not too woried about it, the turbo goes on in lke a month.
-josh
