Jager »
https://forums.nicoclub.com/jager-u75972.html
Tue Oct 23, 2007 9:54 pm
i work at an LFs as well, it keeps the costs almost manageable :P
ADA used to build tanks that were at least in name sponsored and approved by takashi amano, if you can get one, you would be very VERY lucky, and they sell for LOADS to serious enthusiasts, the last 20 gallon i saw went for 350 bucks it was a rimless one and was stunning.
if you plan to do SW, the idiom is go big or go home. meaning that the more water volume you have the easier it is for the system to absorb mistakes, and deal with issues. the smaller Sw tanks are total PITA's to work with and maintain, due to how tight the water parameters HAVE to be kept. even evaporated water can kill everything as the salt in the water doesnt evap, so the salinity rises very quickly. most Nano tanks are either sparsly stocked with fish (like 1 tiny goby or a goby shrimp pair) or have no fish and are invert coral tanks as they pollute less. if you have to try it, get a drilled tank, or an overflow kit and a bigger tank to put under it for more overall water volume. you can also store your heaters and other equip down there. or get a nano and a bigger tank and hook them together. keep delicate fish in the smaller tank and whatever others you want in the bigger one.
to give you an idea of cost for a 10 gallon Sw kit this is what id likely spend myself at My cost.
tank 10 buckslighting 100 bucks t5 or a single 70w HQI /metal halidesubstrate and rocks about 100 bucks
now per week i need about 10 gallons of salt mix, and need to do 50+% water changes at least every other day. if i could put a skimmer on it then i could lessen that, but the skimmers for small tanks can be pricey, or are DIY and can be finiky, or ugly (a 4ft pvc air driven skimmer isnt exactly easy to hide.)
so id feel comfortable selling you a kit with everything to get it cycling at about 250ish for ten gallons.
for 600 bucks i can start you with a basic 75 gallon setup. or for 400ish a 55 gallon.
my current 75 system i spent 250 on the tank had the stand built custom so it could handle anything id ever put on it (3/4 solid pine boards and a 2x4 ladder bottom frame) wood was 150ish and we spent 24 hrs building it.
200 for the skimmer used, (it sells for 700 without the pump)pump was 110 bucks 100 bucks for DIY 3000gph modified maxijet powerheads which keep the water current moving (i have about 11000 gph in that tank current wise at any given time. its all chaotic so the fish can swim fairly easily, but i get very little detritus buildup.)
330 for atcost 6 bulb tek fixture including bulbs, (sells for 440 without the 6 bulbs bulbs are 20 a pop.)
spent well over 200 on the rock at literal cost or sold to me as base rock.Sw mix i get 200gallon boxes for 35 bucks my cost
phosphate reactor was 50 bucks had to buy a pump for that too. pump was 40
substrate was 15 bucks a 20lb bag, i got 3 for the main tank and 2 for the refugium section of the sump underneath.
then theres all the various chemicals, water purifiers, food , and maintenance to keep it up.
its a HUGE initial investment. even at wholesale or a bit above, but do it right the first time, or have to start all over and rebuy the expensive equipment after buying the crap stuff. either way its gonna be expensive.
id ask at your LFs if they can put you on the maintenance team, or if you can setup a display tank at the store that you care for first. just so that the initial cost and burden of upkeep is on the store, and you can get the right ways to do things on their dime and not yours. nothing sucks worse then having 1000 bucks in stoney corals go up in smoke cause the temp jumped a degree or the calcium dropped a bit or the skimmer didnt get cleaned out fast enough. or losing all your fish due to poor shipping or such. nothign ever happens fast in SW that is good
if you already feel fairly comfortable with what your doing as far as Sw, give me an idea of what your tryin to do, and the budget your working with as well as what you want the tank to be when it matures (ie reef tank with soft corals, hard corals (sps or LPS) or fish only.
sorry for the long *** post, if i need to i can do a cliffs notes version.
