93 s13 KA24DE-T Fl 386 im back..
pc240sx
Car: 1993 nissan 240sx se
2003 nissan Sentra se R SPEC V
2025 nissan Frontier PRO X
new mod s14 seats in mint conditions .
truckmtr240
Car: 91 240sx hatch
pc240sx wrote:this is what u do when u bore .. i paint the hood roof and trunk ;also add fog ligth all x $20 bucks..
You got bored so you spray painted you car?? :inout:
Nice s14 seats though. I have the same ones.
pc240sx
lol :gapteeth: true . i will paint the car soon .
pc240sx
new update 06/07/11
ready to install ,just i need some spare time .. :ohno:
420sxWETDREAMS
Car: 1991 240sx Hatchback
ready to install ,just i need some spare time .. :ohno:[/quote]
What kit is that?
pc240sx
i dont know ,no name..
SoCal-S13
Car: 1984 Z31 50th Anniversary Edition VG30ET
S13AL wrote:You shouldn't zip tie your spark plug wires together like that, if they run side by side for about a foot voltage can jump wires, causing misfiring problems.
Electromagnetic induction can do crazy things..
smart man. im a network tech and this is a common issue. each wire has an electro magnetic field (emf) that surrounds the outer coating sort of like a bubble. when you have wires too close the emf's can interfere with the signal, in networking youd get a laggy connection and inconsistent data transfer. in a car it will affect the spark possibly causing misfiring.
pc240sx
JA! what is the big deal !! im going x SR20 SWAP :naughty:
pc240sx
i just saw oil on my driveway ;is my valve cover gasket .time for a new one :mad:
pc240sx
happy father day!!!
:spitout:
SkyS13Walker
Car: 1990 240sx Hatch-back
thats the way you Celebrate DAddy Day you Spend it wit ya BABy
:bowrofl: Car LOOKin NYCE
pc240sx
SkyS13Walker wrote:thats the way you Celebrate DAddy Day you Spend it wit ya BABy
:bigthumb:
pc240sx
new knobs
pc240sx
new stuff
new alternator
almost new S14 Power Steering Pump
old pump
thanks to this guys x the help ...
1991-1994-240sx-help-build-tutorial-on- ... 53113.html
pc240sx
new update 08/21/11
i was tired whit this problem ,till i fund it was my ignition switch .now star fast .
cost me $32.10 at ADVANCE AUTO PARTS
after i take the old one
just make sure u do it rigth
total save $180
ps ,never go to a local shop if u can do it your self or just try :chuckle:
1991-1994-240sx-ignition-switch-lock-as ... 32827.html :dblthumb:
Idahos13
Car: 93 240sx hatchback
Would it click when you turned over the key? and it takes a couple tries for the starter to engage? Because this is happening to my car. Sometimes it clicks and other times it starts up on the first try..
danshaz82
Idahos13 wrote:Would it click when you turned over the key? and it takes a couple tries for the starter to engage? Because this is happening to my car. Sometimes it clicks and other times it starts up on the first try..
me too. heres a thread that has some info.
intermittent-no-start-t540218.html
/thread jack
cars looking good tho!
pc240sx
yes i have the same problem beacuse the idiot 2 owner of my car cut some cables for the alarm ;now star like a new car ... :biggrin:
pc240sx
/thread jack
thanks x the comments
pc240sx
new update 08/28/11 i have some time today to put this on my car also clean my coilovers.. :spitout:
pc240sx
after 3 months i have this done ..
also i lower my coilovers .
pc240sx
update 10/02/2011
new crank seal just $6 bucks but ia PITA to replace ,now is done no more oil leak :bowrofl:
alignment my camber and toe was really bad .
cleaning the car ..
420sxWETDREAMS
Looking good man. Maybe I can meet you at one of your meets, unless you come to Lake Mary.
420sxWETDREAMS
I've been trying to finish my 5 lug swap and have everything but the rotors I have are too big and the 350z calipers dont line up with the knuckles. What did you do to covert your rears? Did you keep the stock calipers and bought a 5 lug rotor or re drilled them?
pc240sx
rear swap was easy but i keep my stock calipers also i buy rotors off s14 5 lugs on advance auto was 65 x the pair and new brake pads ..
420sxWETDREAMS
thats awesome and the stock calipers fit nice!
420sxWETDREAMS
pc240sx wrote:rear swap was easy but i keep my stock calipers also i buy rotors off s14 5 lugs on advance auto was 65 x the pair and new brake pads ..
do you know the size of stock rotors.
pc240sx
no just ask x 95 240sx se 5 lugs :yesnod
pc240sx
oh thanksgiving day !!
thanks x this day off...
full tune up day ! new oil and filter ,tire rotation ,new ngk spark plugs ,new belts....
car wash
ready x other 5k
pc240sx
some video of a drift event on GREEN COVE SPRINGS ,FL
