crzycav86 wrote:Which one did you see that was incompletely machined/finished? One person had issues getting his mounted on the top, but apparently that was because he had received a set for a different car, which isn't a quality issue.
There was a thread I ran into that someone had gotten their's with a hole that wasn't fully machined and still had rough edges. I believe it was the adjustment hole for the tool. I can't find it to save my butt, not sure if it was on the UK forum or a US forum.
crzycav86 wrote:D2 recommended a 9kg/mm front and 5kg/mm rear. I suppose a +-2kg/mm for the front and rear should still be within the dampening range. Also, I haven't dealt with coilovers before, but from what I understand, they have to be broken into before the bouncing/noises desist.
Breaking in a coilover does nothing to reduce bouncing. Bouncing is a result of the dampening being insufficient to the spring rate. Funny how they suggest 9 / 5 ... because thats a 80% stiffer front spring rate, which is not ideal for a 240. If it were, then you'd see more substantial companies incorporating similar spring rates. Much less racing vehicles.
Tein suggests no more than +/- 2kgf/mm on their coilovers because they have tuned dampening rates. A coilover that comes with 3.5 - 10+ kgf/mm spring rates without changing the valving is not tuned.
crzycav86 wrote:I'm not sure what binding is. Can you elaborate?
The mounting bracket was binding on the shock body. Evident by the removed finish on the shock body when they (D2) put it on.
crzycav86 wrote:And one guy was missing a couple dampening adjustment knobs(even though you only need/use one).. big woop. That was just a careless mistake by whoever packaged them... doesn't really reflect the quality of the product itself. It's just a reminder that we aren't perfect.
That reflects on the quality control the company has. If something as obvious as that got by them imagine the non-visable passage rates.
crzycav86 wrote:The only real issue that I've heard of was the one posted in this thread. It's possible that this could be a quality issue, or perhaps just a user error? Good thing they're under warranty
Warranty is good, but do you really want to put up with dealing with it? If so, Kia and Hyundai are right up your alley
