NAV hack done! Questions and goodness.
antzrus
Car: '06 M35x Premium/Obsidian/Bourbon/
Rosewood/XM/Tint/
ClearBra/SteelSkidPlate/Genuine CoCo Mats/Michelin CrossClimate2/Nav Hack/M-1
SiMpLyMoDiFiEd wrote:
kermit the guy wrote:hey how much did that cost and it was pretty easy to install?
130 and took 10 mins with bad back and back brace...
Takes a hell'uva lot more than that to take the dash off and then replace it ..?! That's what scares me.
SiMpLyMoDiFiEd
Car: 2006 M45s, GSXR 1000
8 screws if I remember correctly
The00Dustin
Car: 2006 Infiniti M45
sunoco wrote:I was lookin at this before. I just cant decide if its worth 125, you know? I usually use voice anyway when I'm driving. Sometimes it just will not understand the road im saying and it would be nice to be able to type it in....
I've thought about taking pictures of the connectors (either with a measure next to them, or with relevant measurements written down as well) and going to a real radio/electronics store to see if I could get mating connectors. It wouldn't look as clean, but if stuff that matches (or that can be put together to make a match) exists, it would cost far less than that while still allowing easy removal with no cutting or splicing of anything OEM. I figured I'd just use a phone wire and two crimp or punchdown RJ11 jacks between the hoemmade harness and the switch, so even that would be relatively simple to work on (build it all in the kitchen instead of the car). I even have a great, albeit complicated if possible, idea for the swich. Being the lazy bum that I am, I've only thought about it, several times in two years.
mask0425
Car: 07 M45s, Ex 03 G35s 4dr, 95 j30t
SiMpLyMoDiFiEd wrote: works perfectly
Hi, does the harness cause loss of GPS tracking same as wire splicing? I would imagine, the answer would unfortunately be yes... Does it come back to normal RIGHT after you turn the switch off or do you need to slow down to 30 mph as someone had previously mentioned?
Also, have you found a bigger stock-looking switch or something that's at least not as ugly and tiny as the one they included in the package? Photos would be appreciated as your video appears to have been removed... Youtube?
Thnx!
SiMpLyMoDiFiEd
Hey mask I haven't had a chance to work on the switch.. and honestly I haven't used navigation bc 7.2 sucks lol I will repost video.
Tyson
http://static.photobucket.com/player.sw ... EO0010.mp4
mask0425
Cool, thanks! Let us know if you get a chance to play with the nav - how is the GPS tracking, do you need to flip the switch off to restore to normal and/or slow down to 30 mph, etc... Thnx again.
SiMpLyMoDiFiEd
mask0425 wrote:Cool, thanks! Let us know if you get a chance to play with the nav - how is the GPS tracking, do you need to flip the switch off to restore to normal and/or slow down to 30 mph, etc... Thnx again.
Well on way to work this morning I turned gps on and flipped switch.. the map screen freezes but the arrow still turns as you do... Once you flip switch of it takes about 5 sec or so and it picks you up again. I was doing 80 on freeway when it kicked back on
mask0425
Great stuff, thnx, Now, if only someone programming savvy could figure out how reprogram the system's brain to bypass the confirmation screen and all the other electro-nanny BS!
EniGmA1987
Car: '06 Infiniti M35 Sport
With any of the Nav hack versions you will ALWAYS have to flip the switch back to normal mode to allow the GPS to track you properly.
mask0425
You realize that I was talking about SOFTWARE hack, not hardware. If yes, please post an image of a physical switch used with programming code. ;)
EniGmA1987
I didnt realize you were talking about a software hack, no where did I see one mentioned. I dont even know of a software only hack that exists. You would need a dump of the entire NavTeq program and delete the lines of code that do a check against speed and parking brake, then re-compile it and check for and errors. If all is 100% good, which is probably wont be, then you would flash it into the navigation. This would be far more time consuming and dangerous than splicing a wire.
mask0425
Too bad that GeoHot dude (of the iphone and PS3 fame) just got hired by Facebook and may not be willing or able to accommodate our request.
Anyways, it was a tongue-in-cheek/wishful thinking comment. There are not that many M's for someone to even start looking into this. I don't suppose that very many hackers drive the M's either... Besides, correct me if I am wrong, didn't Infiniti get rid of at least some of the annoyances on the newer cars (i.e. OK to use Nav after each and every start)?
Do I dare to make the next wishful request to link the front passenger air bag sensor and the Nav functionality so the passenger could input the info while the car is moving?
jay7227021
Car: 2007 Infiniti M35 Sport
hey guys new to the site and want to do the nav hack on my M. My question is where did people get the round dpdt rocker from? Ive seen it in pictures but cant find it in stores. Ive tried RadioShack, Home Depot, electrical supply places. In Boston so if anyone knows where I can get the round rocker dpdt Id sppreciate the info.
EniGmA1987
Amazon.com :)
EDIT: I think it was this one that I got:
http://www.amazon.com/Mini-Rocker-Switc ... 27&sr=1-17
pedsemdoc
Car: 2013 M37 Sport - SOLD, Premium/Tech/Sport Journey
Carbon fiber engine cover
GT Spec front tower strut bar
R2C Intakes
Oil catch cans
Custom Start button LEDs
had to buy mine online
need a double pole, double throw switch
couple of sites:
I used the mouser.com switch for my install
http://www.mouser.com/ProductDetail/Mou ... iBbc5m8%3d
http://parts.digikey.com/1/parts/171329 ... c1100.html
http://www.newark.com/cherry/kdh3bna1bb ... dp/07P8620
hkspyder
Car: m37
How did you remove the panels to get to the nav & stereo?
EniGmA1987
Just remove all the screws and slide stuff out.
hkspyder
Car: m37
Where are the screws i couldnt locate the them. I dont know where to start. Can you tell me where the first set are.
jayfox911
Car: 2006 M35 Sport
hkspyder wrote:Where are the screws i couldnt locate the them. I dont know where to start. Can you tell me where the first set are.
I have nto done it in a while but...
1) remove coup holders (no screws)
2) remove shifter cover, two screws near coup holders then move shifter to N by remove plastic cover near top left of cover, use transmission lock tool from tool kit in trunk.
3) pull off CD/radio cver, two screws on bottom
4) remove cd/radio unit, 4 screws two on each side.
EniGmA1987
Nav is not there though, thats just the stereo. To get to the nav you have to pull the glovebox out, then remove all the screws and take all that stuff off.
itzonlytone
Car: m35
can anyone with non nav help me out? i have an issue with the BRAKE light being on and the beeping sound, any help is greatly appreciated. 2008 m35 non nav non dvd with aux inputs
pedsemdoc
R2C Intakes
Oil catch cans
Hey CLint (EcstaSPT)
can't send you the message about the hack because your PM isn't enabled.
Craig
c_nitty
Car: 2006 M35 Sport
EniGmA1987 wrote:Nice find. That works in our cars?
yes sir i installed it today along with my 3k hid fogs... works perfectly
Edit: video
I know this is old but do you still have the vid of bypass install I have a 2006 M35 I want to do it on?
DRA77
Does this work on 2007 M35?
mikelo81
Car: m45
Does anybody know where I can buy the kit & where I can get it done in the Miami area or in queens nyc?
Larz
Car: 2019 Q70-L RWD
I bought the TVK module for my Nav-Hack on my 09 M35. It seems an easy job, but the instructions are not clear as to where the parch is done. Is it on the connector on the rear of the radio, or the connector on the rear of the actual screen itself?
EniGmA1987
My hack was done behind the DVD drive, but I know the 08 and 09 models are HDD based so I cant give you completely solid advice. My *guess* would be though that it is done behind the radio since that is more where data connections and stuff would be coming in and out of. But hopefully someone who has done it on an 09 can comment so you are sure.
Larz
Car: 2019 Q70-L RWD
Thanks Enigma. So sorry to post & run but I had to fly home late Friday after some rather bad news about my Auntie. Just got back this morning at about 6am states time. Thanks for responding. I will be doing the hack in the next few days. I already know from reading the earlier posts that the ground has to be a good, secure one for it to work properly so I will keep that in mind as well.
Cheers
Hardwey
Car: 2007 M35x
I just completed the hack on my 2007 M35x... Thank you all for providing clear instructions. It works like a charm I am extremly happy. :) NYC Brooklyn. :mike
Jaime08M45s
Car: 2008 Infiniti M45 S
Can anyone help guide me on how I can do a video bypass while driving on my 2008 Infiniti M45?
Currently the car does not allow video while driving and the only way it will play video is with the e brake on.
Reason: Merged
