NAV hack done! Questions and goodness.
Larz
Car: 2019 Q70-L RWD
Welcome to NICO. There are a couple of companies that offer a product that is installed behind the center switch )(NAV, air/con, etc) The harness is connected in between your current harness connections and they fit exactly. Infiniti has a safety feature that prevents many uses of NAV, setting, etc when the car is moving, is not in "P", or does not have park brake set. This gizmo by passes the safety feature so that all functions of the system are usable whist driving.
Here is one of the sites who offer this bypass:
http://www.prestigioussociety.com/?page_id=138
There are videos on YouTube that walk you through installation:
https://youtu.be/BL6_6tMDQgs
I have not done this, but I have dismantled my dash, removed and replaced most pieces and parts when I re-covered my dash and this looks much much harder than it actually is. Just remove a little trim, unplug the center switch, connect the harness, and Bob's yer uncle.
NOTE: This video is based on a newer model with a slightly different dash. The 06 & 07 models are easier to take apart, but you must first pop off the small trim piece that lays above the start button to remove the main center switch.
jpeterson
Car: 2006 Infiniti M35x
antzrus wrote:
Tue Apr 21, 2009 8:13 am
paulk22 wrote:Hey
Could someone email the .pdf instructions to me if they have them: [email protected]
Thanks
Hey, just download Ohmster's pictures of the instructions enclosed above. Keep em' as jpegs or convert'em to pdf's. Easy enuf..?
Hey there Antzrus the images no longer appear for Ohmster's hack. Is there any chance you can repost or email? [email protected]
Thanks,
heedman
Car: 2007 Infiniti M35x
I installed mine in the cupholder and it's sight unseen when the cupholder is closed.
crippsx2
Car: 2006 Infiniti M45
I keep hearing about "how this topic has been discussed in detail" , and yet there is NO answer given. I found one place where instructions are given, but the links to the posted images are no longer valid.
HERE : 2008-m35x-nav-hack-t428997.html#p4809140
Telling me to go purchase a 400 dollar wiring harness (that still requires a vast degree of knowledge to install) , is completely irrelevant to providing a bypass. Thats like me asking how to change a car tire , and getting told to guy buy a new car that just comes with 4 tires already installed.
Does anyone know how to ACTUALLY do this ? IE: snip some wires and stick a toggle switch somewhere like a normal person ?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Actually, on most N/I models, there's a "speed sensor" input on the AV Unit that you can just snip. Consult the "connector values" in the SM for the AV Unit. Note that Nissan will not be responsible if you crash while watching Dukes of Hazzard. ;)
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Jaime08M45s wrote:
Wed Mar 16, 2016 1:43 pm
Can anyone help guide me on how I can do a video bypass while driving on my 2008 Infiniti M45?
Currently the car does not allow video while driving and the only way it will play video is with the e brake on.
crippsx2 wrote:
Sat Feb 13, 2021 12:13 pm
Merged with existing topic. Please read the previous posts. Thank you.
EniGmA1987
Car: '06 Infiniti M35 Sport
I have the nav hack done in my car, but unfortunately one of the wires broke off a couple years ago at some point. If I ever get around to fixing the wires Ill try and take a couple pictures of what it looks like complete so that people can have images again to see which wires are cut.
Remo15
Hey guys I'm new to forum and I want to do the nav hack but none of the pictures are showing. Is there anyway or anywhere I can go to the some pictures on how to do this? I have a 06 M35x with nav
Ilya
Unfortunately the pictures have been lost...:(
Remo15
Mannnn...I really just need to know what wire to splice into
Ilya
Perhaps you could discern the wire by studying the schematic available in my signature on this site via the factory service manual? Not sure if it's labeled there as needed but perhaps it can be figured out...
Remo15
Ok thanks I'll do some studying over it
pedsemdoc
Car: 2013 M37 Sport - SOLD, Premium/Tech/Sport Journey
Carbon fiber engine cover
GT Spec front tower strut bar
R2C Intakes
Oil catch cans
Custom Start button LEDs
I saved the old original website pages on how to do the Nav Hack to a PDF file - here's a link to my Google Drive for the document:
https://drive.google.com/file/d/1wvIQAg ... sp=sharing
Craig
Remo15
Thanks alot
EniGmA1987
pedsemdoc wrote:
Sat Apr 10, 2021 12:07 pm
Craig
You sir are awesome :dblthumb:
