about a year ago i saw a red 93 300zx NA, which was rough all around but not terrible the guy i bought it from started to fix it up, he started with a suspension re-fresh.. new injectors ect.... but working on this car put him into debt (auto title loan) so thats where i came in a bought the car and took over bringing the car back to life.
Heres the earliest picture i have of it
20160401_134640 by sounderror, on FlickrAt this point i had just removed the bubbling tint on the front windows, and was removing the rats nest of wires from an audio system that was no longer there. i wish i had a picture of the wires i removed but it was a hack job to say the least.
Next i fixed its idle problem, which was a busted coil pack boot, replaced spark plug seals, a few other seals, cracked coil pack connectors, cleaned the IACV system added the Z1 Hoses, under plenum water hose delete, along with half a EGR delete, charcoal canister delete, you know all the normal deletes.ran great through the summer heat no real issues
20161203_113536 by sounderror, on FlickrJust some more pictures before i type more story
20161203_112954 by sounderror, on Flickr
20161203_112908 by sounderror, on Flickr
20161203_113406 by sounderror, on Flickr
20161203_113458 by sounderror, on FlickrDeleted the rear wiper....
20161023_104026 by sounderror, on Flickr
20161023_105648 by sounderror, on Flickrand the interior is torn out as i was working on fixing the AC which is on hold at the moment...
20161203_113124 by sounderror, on Flickrnow about a month ago i decide to do a compression test because i was about to do the full 120k maintenance and drop a bunch more money into it. i find i have low compression on 3 of my 6 cylinders. at this point i was just considering doing an engine rebuild since a TT swap was out of my budget since the only motors where the imports which you know how those go lol... (also shout out to Nolimit for giving his guidance on this issue)
So as i prepare and read up on this engine rebuild i see an ad on Craigslist... its very vague "300zx engine for sale, ran when i pulled it" $300 . from the pictures i noticed it was a TT engine, but he made no mention of that in the ad. so i get in contact with him and make a date to well buy it.....at that point i figured it was to cheap to pass up. this led me on a 2 hour drive to Phoenix in a truck i had rented from home depot. so i show up and he loads it up into my truck then says he has intercoolers and piping which he wants $50 for so i figured well stock side mounts why not so i pay him then he just starts collecting tons of stuff stuffing it into box's and bags. at this point i have no idea what all was givin to me and i didnt much care i just wanted to get home...
so its about 12 at night and i finally get everything into the back yard where it sat for the night. next morning i went and inspected what i had just spent my money on so now for the pictures!
20161203_110404 by sounderror, on Flickrlightweight pully. +1
20161203_110418 by sounderror, on Flickryellow top Nismo fuel injectors (555cc), upgraded fuel rail???
20161203_110459 by sounderror, on FlickrZ1 powersteering hose....
20161203_110536 by sounderror, on Flickr
20161203_110550 by sounderror, on Flickr
20161203_110603 by sounderror, on FlickrAs you can tell some stuff is bent... such as these (not sure on what they are called) on both sides but this one is worse
20161203_110629 by sounderror, on FlickrNow i started going through the boxes to find Dual Pop, with dual MAF, also greedy side mounts not the stock like i originally thought...
20161203_111255 by sounderror, on FlickrA beat up koyo Rad and CZP top bracket..
20161203_111459 by sounderror, on Flickra bunch of stock piping Z1 hardlines, AC condenser fan and a pair of T-Top bags,
20161203_111839 by sounderror, on Flickra spare plenum that someone started grinding down to be polished
20161203_112031 by sounderror, on Flickrand a set of headlights with HID (unknown color Temp)
20161203_111343 by sounderror, on FlickrDefi gauges in pillar pod (unsure if they are legit defi or not they look in between fake and real) Turbo timer, boost controller,HKS BOV's, Tuned ECU its tough to make out but it was possibly tuned 2 different times why its torn off is unknown guess i will find out eventually. one little box is for the stock suspesion in a TT no use to me, then the medium box i have no clue what it is.. lol
20161203_115203 by sounderror, on Flickrheres the engine harness..
20161203_115215 by sounderror, on Flickrthats everything i got with my engine purchase as you can tell i got way more then what i paid for very lucky
also picked up this TT front bumper $100
20161203_112044 by sounderror, on Flickrand my black friday shopping on both Z1 and CZP, Walbro 485, TT performance clutch kit with all the upgrades and the TT flywheel. Shim plate for starter, the Z1 engine mounts, the Z1 shortshifter, then those connectors where things i never got around to installing on my NA so those will be added to my TT harness.
20161203_120300 by sounderror, on Flickri think all im missing for the swap is an oil cooler.... and maintenance type stuff... or at least thats what im hoping... (input welcome)
oh and a bought an engine stand which the engine was supposed to be on in the pictures but i never bought and bolts to attach the engine to it anyone know the size i need? so gotta figure that out.
20161203_112559 by sounderror, on Flickri know pretty much nothing about the engine i bought, the guy bought it from a running car which he drove and apparently pulled the engine out afterwards, he said the guy wanted more power so probably a V8 swap, the guy i got it from was going to swap it into some older truck then lost interest... so it has sat for about a year, in his garage. he said that it was rebuilt by the guy he bought it from at some point (who knows) and the car it came out of had 190k so idk, im hoping on the rebuild being the truth.... from the mods i would say its very possible but i wont know till i crack it open and inspect it....oil cap is clean and from what i can see inside looks extremely clean but im a noob when it comes to engines..
