Carl H »
https://forums.nicoclub.com/carl-h-u9196.html
Thu Nov 27, 2008 2:56 pm
back up to the top with another update...car is closer and closer to being 100% complete but i have hit a snare or two as the throwout bearing blewup with some spirited driving during its testing period.reason i suspect the TOB is that hydraulics are still functional, bellhousing is in one piece and the car shifts when the engine is stopped.It had been making noise since i had fitted the engine originally so i knew that it might fail soon and was probably a bad bearing from the start.I was however able to modify the parts needed for the intake, so it has a proper air cleaner assembly on it now.A friend had given me a filtercharger kit for a sohc ka as he was unable to use it anymore due to his turbo setup...so i decided to just modify the adaptor plate to bolt the q maf to.here is the modified adaptor plate and maf all bolted together, the velocity stack id needed to be opened up about .25" to suit the 90mm maf opening.
front view of the modified plate and maf:
decided due to the size of the filtercharger that it would be best to go ahead and put the maf in the fenderwell for not only space but also to insulate it from engine bay heat, the pipework is 3.5" mandrel bent.
quick shot of the maf/filter/extention pipe:
splash guard has been refitted to keep water from well splashing onto the filter and causing operational issues like hydrolocking.
also was able to start on the cowl hood sides and back, havent decided on how i want to seal off the sides/back to keep them watertight.using some nice 16ga sheet steel a friend gave to me i started tracing out the needed patterns for the sides and cut them out...here only the passenger is cut.
and the cut passenger side test fitted...needs more triming but that is stuff to be done under the hood.
depending on how motivated i am tommorow i might pull the transmission and inspect the damage...i have a new complete clutch kit here if i have to replace the clutch but i hope it wont come down to that.worst case scenario the trans assploded, best case its just a faulty throwout bearing...we'll see.
