Carl H wrote:I was able to get most of the cooling system figured out tho
plumbing the radiator turned out to be simple...to reroute the lower hose i took the stock bracket and trimmed down the mount tab and flipped it upside down, then bolted it to the head using one of the thru cover bolts...worked very well.hoses were plumbed using the ka hoses with minor trimming but i'll need a joiner of sorts for the lower hose as can be seen from the pictures; that or a single piece of hose, would be perfered but hard to find.might be stuck with the stock radiator and stock ac cooling fan for now, a friend has a taurus sho fan which I'll try to mount for ultimate cooling.
front shot:
drivers:
passenger, note the rerouted solid pipe and connection lacking a joiner.
Carl,
Just trying to give you a heads up. There is no way that the stock radiator and AC fan will keep up with the heat produced by this motor on a hot day. I'm speaking from experience.
My cooling setup is as follows... Koyorad AL race radiator and stock AC fan. I had the lower inlet moved to the other side to ease hose routing and to promote cross core flow, which the KA setup does not. I had a bung welded into the radiator for a thermoswitch that turns the fans on at 190 and off at 170. With the car idling in my driveway, hood up, on an 82 degree day, the fan came on at 190 and never shut off. I watched my coolant temp gauge come down to 182ish from 190 and then stay there. Had the hood been closed or if there was a load on the motor I would have been in trouble. Keep in mind, I don't have a heater core at all, so that reduces my cooling capacity somewhat, but with my much larger than stock radiator I was still in trouble. I'm now looking into a custom shroud on the AC fan. If that doesn't work, it'll be a dual fan setup...
There are two major players in cooling system capacity. Fan CFM and fluid volume. My setup has volume but limited CFM. Yours has neither... start saving the pennies!
