Carl H »
https://forums.nicoclub.com/carl-h-u9196.html
Mon Aug 04, 2008 5:22 pm
dont care too much about the paint as its complete crap anyways...gotta love maaco.bit more progress today, started clearancing the frame rails but didnt do both sides.dont know what i was thinking but low and behold the oil filter hits, do'oh!
removed the battery tray and all 50 spotwelds holding it in place, began to mark off for alternator clearance:
frame rail cut:
quick shot of the engine in the car, not bolted in but resting on the ac compressor bracket...will have to be cut off for proper clearance.
suspention droop is not apparent, car appears to sit HIGHER than with the ka in place,odd to say the least.
front shot of the engine to the radiator support, again good clearance here.
alternator and clearanced rail...
oil filter fouling on the frame rail, FAIL!
shot of the rear of the trans bellhousing, ample clearance around the bellhousing so much that i could change the clutch in car.
while the engine was mock fitted into the car the slave was bolted up to the trans, aside from the normal pedal adjustment required for good feel the clutch engaged and disengaged smoothly with no issues.i suspect next time the engine goes in i'll have a large majority of the stuff needed for modifications marked, clearnaced, and/or cut...so with any luck it will be headder fab time.
