My Vert 5spd swap and other work
biggie
Thanks to some help from a friend. Got the EGR off and header on. Rerouted one vaccum tube, so hope that works. Just need to get intake mounted and undertray back on (probably this week/weekend).
2.4Loflove
Car: 1993 Nissan 240SX SE
Good job on the header install and other work! I just got done taking my EGR off of my hatch, and it fixed my hesitation problem. Have you had a chance to run the car with the new header?
biggie
2.4Loflove wrote:Good job on the header install and other work! I just got done taking my EGR off of my hatch, and it fixed my hesitation problem. Have you had a chance to run the car with the new header?
Nope, been lazy and have to put the undertray back on and put my old injen intake pipe on. Got a used K&N cone to go on the intake, so washed it last night, will need to oil it. Probably Saturday I'll see about a test drive.
But my old coupe had a pacesetter, 2.5" catco, and HKS catback, so I kind of know what to expect. Just figure the Vert is going to be insanely loud now.
biggie
Put back together last night, went to bed pissed it wasn't running right. Then while in bed realized I didn't hook up the MAF. Running well today, just still a small exhaust leak at where the header meets collector, going to have to go with a full threaded stud to tighten it enough (or call Pacesetter about getting just their hardware).
Doesn't seem much louder, surprisingly.
2.4Loflove
Nice, I'm thinking about ditch my full CAI and relocating my battery so I can make the intake as short as possible on the opposite side. I'm tired of having to worry about hydro-locking my beast.
biggie
Only really have to worry about hydrolocking if you are driving through standing water that's up to the filter. I wouldn't mind getting the Injen CAI extension, but seems they are way overpriced these days.
biggie
Still may have a small exhaust leak even after different bolts and tightening everything up again. When done today it started raining so didn't go out on a test drive (probably tomorrow).
Worked on the hood. Started sanding with 2000 grit, but wasn't working as well as I'd hoped. Instead went and picked up a turtle wax 10" polisher/buffer (since harbor freight was out of them). Picked up Meguiar's Compound and Wax. Worked better than I expected, and I'll be doing my CF hood on my coupe sometime soon.
Where it started:
After the Ulitmate Compound on orbital and hand drying with terry towel:
After hand applying Carnuba Wax and removing/buffing with orbital:
On the car:
Products:
biggie
A search for new catback has begun. N1 dual knockoff is now too low after the header install and it restricts sway bar choices.
biggie
Did figure out the exhaust leak. 2.5" header extension and 3" cat don't like each other, had to use a 2.5" and 3" gasket (only had 3" previously). Believe it is mostly gone now.
New exhaust on the way, found a used Megan Type 2 on ebay.
krash
Where was it sitting too low?
biggie
krash wrote:Where was it sitting too low?
The resonator, center of the car. The N1 dual is for sale if you know anyone looking.
biggie
Noticed this last time I had the cat on upside down, so that was tilting the N1 dual, making it lower than normal.
Put the Megan Type 2 on:
biggie
Have a couple things to do tomorrow:
- Have an extra transmission mount that I filled with poly (liquid nails) swapping that out
- Still small exhaust leak where 2.5" header extention meets 3" Cat. Found 2.5" flange that should cover it and use as a spacer between, also adding another 3" flange behind Cat (since it seems the exhaust is being pulled back an 1" or so).
May remove fan shroud and clutch fan. Haven't decided if I trust it to stay cool after that. Since I won't be installing the Altima fans for a little while.
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
How does that exhaust sound? It looks really stock and I kinda want one
biggie
-RJ- wrote:How does that exhaust sound? It looks really stock and I kinda want one
Sounds very good and deep at idle and low RPMs. But at high RPMs it does get raspy, say over 3,500 or so.
biggie
Got a used cooling panel and installed it yesterday. Need to wash the car and get some pics before it gets cold.
biggie
I was slow on those pics^
Small update:
Went to install my old SS Braided lines and bleed the brakes Sunday. Everything went fine until I started to bleed the fronts. Both front bleeder valves are stuck. Letting them soak in PB Blaster this week and ordered 2 new ones from the Dealership (they'll be here Thursday).
Hope to replace them and bleed the fronts this weekend.
Will try to take a few pics as well.
biggie
Finally got the bleeders out of the front calipers. Had to take them off and put it on a bench vice to remove them. New ones were $20 at the dealership
Fronts
Rears
The pain in the a** bleeders.
biggie
Got the some ST sway bars and put them on. And a pic of the cooling panel I picked up a while back.
biggie
Been driving the Vert this week with the G bumper getting painted.
Noticed the clutch fluid is leaking somewhere. Not much and its nothing noticable on the garage, so must be happening while driving. Probably need to check slave connection.
Also hope to start on a couple things with the car soon:
- power side mirror install
- remove back seat and spray rust converter/paint to protect it (noticed light rust when we did the speaker install a few years ago)
biggie
Took a pic since I washed it.
biggie
Broke a J hook and may be impossible to find a replacement.
And my clutch master may be leaking at the plunger inside the car.
biggie
Found a vert in pullapart Charlotte picked up a few things including the hooks.
biggie
Have been wondering why the Vert was so sluggish. Had no power over 2500 rpm. Then maf was mention by a friend. Swapped maf and reset the ECU yesterday. Car is actually fun to drive again. Now if it would just cool off outside.
2.4Loflove
I'm selling my piping by the way.... fs-igen-cai-extension-piping-clamps-t560183.html
biggie
Good price, I just don't have any extra money (new tires on my G35 have me in debt).
2.4Loflove
Ha no worries I know exactly where you're coming from!
Loki
Car: 1994 Nissan 240SX Convertible
2010 Toyota FJ Cruiser
2001 Ford F-150 SVT Lightning
Hey Biggie, any tips to getting that EGR tube off? I'm gonna get a local shop to fit a new header on, but I believe my current EGR tube may be frozen to the current header. Was considering buying a new one and telling the shop to chop and reinstall.
biggie
Soaked mine every day with pb blaster for like 4-5 days, then big wrench.
biggie
Since I had to take pics for the Hagerty application, y'all get pics. Lots of them.
