I've been away for quite a while. Been super busy with school and getting this blasted car back together. It finally fired back up last night!
Thanks to Carl at BlackBoxTuning for tuning the ecu for me. I havent had a change to drive it more than a couple feet but so far it seems to run pretty well. AFR's look good idling. And so far the LC1 hasn't given me any issues yet... hopefully it'll stay like that. It specifically says that if you don't solder all of the grounds (the xd-16's and the LC1's) to the same point and put em all in the SAME lug that you can pick up unwanted noise. So not sure if you guys did that or not.
ANyways, i also have the newer style injectors on the older style manifold. Runs GREAT so far. Can't wait to get it out on the road.
Now here's the much required start-up video.
Finally, after MANY hours of work. Thing is back up and running. Cleaner than ever before.
Description:First start after pulling the engine and replacing the transmission. Also did a wire tuck and painted the bay along with some other goodies. There is some abnormal valve noise at first but i think it was a partially stuck lifter as the engine had been sitting a while. Once it warmed up a bit the noise went away so i think it'll be alright.
http://www.youtube.com/watch?v=xw__wF0agJs
