hannibal wrote:Oops. Must have had you confused with someone else
It's cool, no worries.
drkidd22 wrote:I have to give you +++++ on this. I think I'm going to get fired from work today cuz I have not done s*** during the morning because of reading every single post of this F**ng Great build. First of all you the man because you didn't give up on you goal when you was ripped with the clip with the SR. I had a simillar problem to your and almost gave up on my car build up, but my mom told me that I had to finish what I started and not to give up on it and she's not even a car girl. So great Job!. I'm going on my third year on my '89 240sx SR20DET build and all I need right now is to get it painted.And also I like that everything was done by you, just like I have done with my car, from putting the engine in to wiring the freaking thing up, not like other people that take it to a shop and have someone else do it for them then they say, oh look what I built.
Thanks, glad i was able to get you fired haha. But seriously, dont give up. It'll be worth it.
So here's an update. Some of these things i did a few months ago.
Knock sensors! These are from a 350z which are WAY cheaper than buying q45 knock sensors. I think they were like 35 bucks each or something like that. Anyways, get a pigtail from a KA injector harness and then solder them in place of the q45 knock sensor connectors.
Here's the knock sensors i received.
New knock sensor on the right, old on the left. Notice the difference in plugs.
Injector harness pigtails needed to be soldered.
You also have to cut one of the notches off the Z's knock sensors in order for the plug to fit. Once you do that it snaps right on.
Believe it or not, i was able to get both knock sensors replaced without removing the coolant y-connector.
On ething i noteced though is that the 350z knock sensor diagram shows that bothe pins are used. But i figured out one just needs to be grounded. I think i just put a crimp connector on the right pin (when looking at the knock sensor directly) and then twisted it and grounded it with the bolt that secures the knock sensor to the block. No problems thus far. Knock sensor code went away.
Plenum!!
So i had an extra plenum lying around and decided to clean it. Took it to a place to get it cleaned and they said they couldn't boil it because it was aluminum. So they put it in this tank that shot hot soapy water everywhere... Needless to say it didnt do much at all. Was kinda pissed. I could do more with acetone and a toothbrush when i brought it back to my house.
Anyways, told my buddy about it and got hooked me up with some free bead blasting!
Here's some pics after i painted the runners and plenum so they dont corrode.
Also finally got an adjustable FPR. Tried out the megan one. Got it from FRsport. It's working pretty well so far from what i can tell.
Also got a set of 8 used injectors for a pretty awesome price. Helped figure out my stumbling problems and what not. Although i know they wont last forever..
Thats all that i can think of right now. Other than that i'm having big cooling problems. My system isn't pressurizing for some reason. Going to bleed the system, replace thermostat, caps, and possibly get a new water pump and another new/different radiator if nothing else seems to be working.
