centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Fri Jul 01, 2016 12:30 pm
Hi James, welcome to the forums! The difficulty level is going to be very similar to the difficulty level of RHD swapping a 240sx. You can search to find threads about that. There may be a write up, I don't remember. I would figure the hard part is actually sourcing the parts you'll need. A RHD dashboard, steering rack, etc. That swap is a bit less common in the US, so donor parts may be as complicated as getting a front end clip from UK, Australia, or Japan. Good luck with pimping your ride!
PS - if you look at the posts in a thread, you can see a date for when the post was made. This thread you found was last posted on in 2008. So, getting responses from the other posters might not happen. You could introduce yourself and your car in the Sentra Forum, mention your goals and get some conversation started there if you wanted to.
