Step 01 was the engine swap (sr20). Now the car goes, but doesn't exactly stop. I put in new rotors and pads in the front when I did the swap (cheapest I could find @ carquest) to tide me over until I could do my real brake swap.
What's in the works?5 lug conversionz brakes all aroundz rims and tires.
Parts gathered:
5 lug hubs front and rear. New hubs and wheel bearings. Def. need to be replaced on a 15 year old car.
Powerslot rotors front and rear
Z32 Rear calipers
Ferodo DS2500 Front and rear brake pads
G35 Coupe Ebrake lines
An idea of what they'll look like:
Z32 NA rims. Street rims. Eventually upgrade to lightweight 17s.
New 1 1/16th brake master cylinder.
What else is needed? Front calipers & tires to get the setup in and running. I'm planning on getting longer wheel studs (ARP) and some light weight lugnuts. The rears need new hardware kits already, I'm thinking about going for the whole rebuild and powdercoating deal. That's still up in the air. I've already got the conversion lines to use z32 calipers on a 240sx. Just didn't remember to take pictures of 'em.
I settled on the pads by talking to some friends who know more about this stuff than I do. They really recommended them if I was serious about tracking my car for real. I have z32 uprights as well for the rear, but I'll wait to put those in until I can afford to do my suspension setup.
I really can't wait to get these things on. Even doing some spirited driving on back roads the brakes do not give you confidence. You really gotta give yourself some room, or else you'll put yourself in a tree.
More pix can be found here:
http://www.bumnah.com/brakes
I will keep updating this thread as I progress.
Thanks for looking.
