Made some more progress. I got the front brakes all taken care of. Easy as pie; IF I didn't screw one of my calipers up. I wasn't paying attention and I stripped the hole where the hydraulic lines goes into the back of the caliper. Spent a few days trying to get it repaired. I luckily found another re manufactured caliper at advance auto. At first they sent me an Iron one, but second time around I ordered up the proper one. I took it, and painted it red to match my other 3 and knocked it out. I was pissed that I made such an amateur mistake.
I also sourced up a HICAS front steering rack. This is my 3rd attempt at locating one. 3rd times a charm, because this bad boy is 2.6 turns lock to lock. I've got my old rack all unbolted and ready to come out, just need a second hand to help wiggle it out. Wiggle the new sweetness in and the front is pretty much wrapped up. I also installed the 1 1/16 master cylinder. Plug and play, 5 min job.
I need new parking brake cables, because the G35 coupe cables DEF. DO NOT WORK. Those should be in tomorrow. I won't have time until Friday afternoon to hit up the install. I've got the whole parking brake deal figured out and swapping it all in should be pretty straight forward. With any luck I'm hoping to have it running by Sunday. I'm dieing to drive this thing!
Pix:
The brakes in all their glory!
HICAS Hotness
More pix @
http://www.bumnah.com/brakes
