My clean new coupe=)
veilside180sx
My new clean '92 Coupe
Finally have a shell I like well enough to put all my parts onto. Since I've gone through 3 in the time of putting all this together.=) Don't mind all the other cars...fathers day get together.
Passenger side shot
Drivers side shot
Z32 Brakes
Freshly powdercoated subframe[/QUOTE]
Cleanest wheel well I've ever seen. Whole underside of the car looks like this
Modified by veilside180sx at 6:47 AM 6/23/2005
Modified by veilside180sx at 8:00 AM 6/23/2005
veilside180sx
Here's my build list for it too.
SOHC motor: T3/T04E 50 trim (looking into PK GT35 though) JGS Manifold JGS Wastegate JGS BOV Custom Sheet metal intake manifold Emissions removed Espelir JGT500 Exhaust
Built Spare Block:(awaiting cash flow Arias Pistons Crower Rods Clevite Bearings PDM Cam or JWT
Fuel and Ignition Control: AEM EMS w/Map Sensor 720cc Injectors MSD 6a Ignition MSD Blaster 2 Coil
Drivetrain: Heavy Duty Pressure Plate Custom Kevlar Clutch VLSD C's Short Shifter
Brakes:Z32 30mm Aluminum CalipersPBR Ceramic Pads
Suspension: D2 Coilovers 7/5 w/ Pillowball mounts SPL Tension Rods SPL Traction Rods SPL Toe Rods SPL Rear Upper Control Arms Tein Inner/Outer Tie Rods Whiteline Adjustable Sway Bars Boxed/Welded LCA ES Bushing Set to cover parts that the rest doesn't cover ES Subframe Bushings Custom Nismo Power Bar type tension rod bracket New Front Lower Control Arms w/ ES Poly Bushing
Interior: Momo Monte Carlo Wheel Sentra B13 or B15 seats(have both, haven't decided which to use)
Footwork: 5Zigen FN01R-C 17x8 35 offset w/ 215/45 F 235/45 R
Modified by veilside180sx at 9:50 AM 6/20/2005
DRIFTEADOR
jeez, how many miles are on that thing. it looks new. like it never finished assembly
veilside180sx
Actually iirc it has 170,000 miles. It has a lot of time invested in cleaning it all up. The motor will be equally as blingin'=) Polishing the front cover, valve cover, my custom intake manifold will be shiny already, also the turbo housing. Should be really nice, I also have a nice plug wire shield that is mirror polished too.
Florida240sx
I want it.
veilside180sx
ummm...looks like your already a 240 whore.=)
So am I as I have a hatch I got hit in(red car behind it), a hatch shell in the garage(need to sell) and then this new one.
virus77
Car: 95 S14, 71 240z, 97 e320
its a nice color and very clean too, looks like you have alot of work ahead of you.
Florida240sx
I win because my coupe is a vert.
hannibal
Car: Red Line to Glenmont
Looks great! Thats a very clean shell...
veilside180sx
You know surprisingly I think the hardest part is cleaning things.
Ripping apart the suspension and motors of these things is actually quite easy.(as far as this stuff goes)
I'll document putting back together all of it, as to make it easier for others who are playing with this stuff.
Modified by veilside180sx at 12:02 PM 6/20/2005
Structure240sx
very clean and very nice
turbo98_240sx
Car: computers, cars, anything that can do something and be made to do it faster stronger or better
You could eat off of that thing!! damn!!! dude, nice job
turtl631
Car: S14
Nice plans! Report how the JGS WG and BOV work, I will probably get them eventually myself. Instead of the whiteline sways, you might want to check out the Progress bars. They come with pillowball endlinks for less than you can get the whitelines+SPL pillowball endlinks.
veilside180sx
When you already have Whiteline bars, you run Whiteline.=)
If I was buying new, I agree the Progress are better.
I've been happy with everything I've purchased from Lance (JGS) so I'm sure they will both perform as expected.=) I will though review them when I get it all back together.
nismofly
Car: 89 Nissan 240SX Hatch
you owe me a keyboard!
**** now i gotta clean this up...
veilside180sx
ROFL...=)
veilside180sx
These are pics of the suspension on the old red car (in background), much dirtier.=( New front lower control arms(with poly bushings) were added to this, as well as rear that were boxed on the bottom and powdercoated black.(with poly bushings)
Nismo_Freak
Old school SPL upper arms hehe.
veilside180sx
Yup I think I bought one of the last sets you guys had. Wish I would've gotten the Pro ones so they matched the rest, what I get for being cheap for once. I'll have to settle for powdercoating it black. (clashes with the D2's)
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
I want to buy it
veilside180sx
sean8564 wrote:I want to buy it
Not for sale=)
Craving4Boost
Car: 91 240sx fastback
very clean and looks fun
veilside180sx
Pictures after todays progress...
Completed drivers corner
Clean diff cover=)
Rear spindles put together, will be installed on subframe tomorrow
eddiec
Car: 91 S13
nothing but sweetness man.
could you post a pic of the rear arms that you "boxed"?
veilside180sx
Well I would, but they are at the powdercoaters. So as soon as I get them back I'll do that. It's basically a plate that is welded across the bottom side, with a hole cut in it for the sway bar mount. They are much stronger afterwards.
eddiec
Car: 91 S13
nice. i look forward to it.
hannibal
Very nice. The rear suspension looks so good, I didnt even recognize it. Are there any stock pieces left to upgrade??
veilside180sx
The lower control arms need to upgraded, which I'll do eventually. As of now I'm to busy with the motor to put more into the suspension for awhile. The lowers do have ES bushings in them though, but I would love a set of SPL LCA's.
Modified by veilside180sx at 8:32 AM 6/24/2005
veilside180sx
The rear subframe is all put together, besides the LCA's. Hopefully they will come back soon, so I can finish. I'll probably throw on a old set in the mean time. So I can finish up the motor and drop it in.
240sxHitman
Car: Boosted '91 240sx
i love to see a start from stratch build up, looking good so far cant wait to see more
