Elusive, wow dude glad to see you're still around after the Org. I had no idea you'd been active on here the past couple of years. You've really gone to town on your VE! I had kind of assumed you moved on from the 3rd gen after all this time.
I'm still rocking my TK3 VE. Been boosted about 2 years. Here she sits now:
Broke a ringland last year and block is currently at the machine shop getting bored .020 over for Z32 Wiseco pistons, crank polished and Eagle rods. Should be back up and pushing some even more serious HP later this summer.
You mention gears - do you mind sharing whatever info you've gleaned about that? I'm currently looking into beefed up internals too. Did you know that PAR made a helical cut gearset for the Maxima-specific RS5F50V back in 2008, complete with needle roller bearings, and made 15 sets, some of which are still available? It's a direct fit for the 4th gen and the 5 speed manual early 5th gen. As best I can tell, PAR actually only ever sold one set. Unfortunately the whole gearset won't fit the 3rd gen because the 3rd gen has a different reverse gear setup from the 4th and 5th gen - the 3rd gen two reverse idler gears while the 4th and 5th has only one. If we swapped in the 4th/5th gen PAR gearset we would have no reverse.
BUT I have been doing a lot of research the past week or two, and you know what else has the RS5F50V AND also has the dual reverse gear setup? The Pulsar GTiR. I strongly suspect the VE transmission is identical internally to the Pulsar GTiR including the reverse gear setup, and I'm actually currently in the process of trying to confirm this with PAR. If this is true, this means we can actually use totally off-the shelf Pulsar GTiR aftermarket beefed up gearsets from PAR (or PPG or anybody else for that matter).
Anyway, I'll have to keep up with your thread here. Glad to see you around man.
