some more pics... this thread is gettin huuuge, but hopefully it will give peeps ideas as to what you can do with a 240, or any car for that matter...
in this pic i was going to finish puttin first layer of fiberglass down on all sides, out in the sun so the resin would cure crazy fast... got jello?
:pface
went all out and decided to start bondoing the top piece since i ran outta fiberglass supplies...
U-Dimension 8k.1, beautiful amp, good for testing purposes, just not enough power for my liking
i ran the speaker wire out the ports so that i didn't have to cut a hole in the back of my box quite yet... oh and you can see the beautiful duct tape and green tape holding the port extensions on... what you can't see is the hot glue i also used to keep the extensions in place
*edit* my DD installed in the box... this is with the hole cut in the box so the hatch latch could have somewhere to go... unfortunately the resin kinda shrunk the fleece a little and so now i can't get the hatch fully closed... gonna have to bust out the belt sander and go at er'
that's all for now! gonna go do some belt sandin
