I can well imagine that a bad KS on one side or an intermittant harness failure could cause a similar failure.Q_SHIP wrote:I don't even know why I bother answering these posts anymore because someone always tells me I'm wrong. Even though I had the same issues and it infact WAS the knock sensors and harness.
The coilpacks? Not at all, if you determine which ones are defective and replace only those.miata007 wrote:007
You do, but it is just more time, nothing like brain surgery.miata007 wrote:Maxnix,The coils on the passenger sides, access is easy. How difficult is the access to the driver side? When I replaced the KS, the coils on the driver, seems like one has to remove many things before you can get to it (or them).
007
Not possible.miata007 wrote:paranoidjack,
The TCS sensors actually have something to do with engine stumbling????
007
No, of course they don't...I was just making a point that it was the ONLY thing I had changed that wasn't metal and rubber. Just went away after she entered my maintenance program!miata007 wrote:paranoidjack,
007
Tech-in all these idle posts, I don't think I've heard you 2 cents. What is your guess is the root of all this q41 stumble complaining?Q45tech wrote:The 90-96 Q coils were bullet proof in size and design, the Q41 cost cut redesign was significantly less robust and often problematic in different areas of the engine.
Be very careful about comparing the two very very very different models, just as one must segment the 90-93 and 94-95 and the unique 1996.
Only compare apples to apples year groups to year groups.
Duly noted. The question still stands, as I'm sure he would have something more valuable to say than most here *cough*cough*maxnix wrote:If one reads all of Q45tech's posts, one will quickly realize that his interest in the economized build of the VH41DE is minimal.
In particualr, he has mentioned many times the cheapened design of the later colipacks.
actually...one thing I did do....I added a can of BG to every tank for roughly 2 weeks. This seemed to help a bit. Overkill maybe, but I bought the car at 72k so you never can be too careful.Qproject wrote:there were a few people who had replaced their coilpacks (some all 8) with no improvement.
SO IT NOT THE COILPACKS!!!!!!!!!!!!!!!!!!!!!
now that we got that out of the way, what could it be causing this ?
are any of you with this problem getting a CHECK ENGINE LIGHT ?
totaljett wrote:I haven't gotten a check engine light . Not so much as a blink but as I said earlier the scan on my car does have a p0330 code but still no check engine light.
Actually, it does.Qproject wrote:(yo)u mean P0303 right ?
anyhow you guys gotta remember, it could be another problem that is causing that "misfire on cyclinder 3" as the ODB2 code would spit out. It doesn't necessarily mean it IS the cylinder 3.
On that particular car maybe, but on others, maybe not, per my preceding comment about the condition of the intake path. Too little information to make an inference.Qproject wrote:there were a few people who had replaced their coilpacks (some all 8) with no improvement.
Interesting info, how long ago did you have this done? and it is gone completely, no signs of it rearing its ugly head again. If you dont mind me asking, how much did this all cost you?99q45t_vl wrote:In my particular case, the injector #5 and, more recently #2, were the source of the stumble and then misfire. I use only 93 Shell or Chevron gas, had the fuel filter replaced, all regular cleaning (EGR, Plenum, IACV, TB, etc.), and all up-to-date maintenance done (including new PFR5G-11 plugs, PCV, KS, harness, and O2 sensors).
