Knock sensors fail due to heat and age. Same for their harnesses.Qproject wrote:could it be the KNOCK SENSORS?
weren't these known to be faulty on the older g50's ?
Since turning on my AC adjusts the IDLE.
IAC valve is active whether AC is on or not, as I understand it. The on and off again drag of the compressor will require it to cycle more often, of course. Why it (and other parts of the intake path) must be clean before diagnosis is attempted. If it's sticking, it will introduce a stumble.
OK, one last time - there are many possible causes for the stumbling. One must start from a known good baseline (clean intake path, TB, IAC & EGR valves and interior manifold tube, air and fuel filter) and proceed systematically to diagnose the problems, provided one does not have supernatural extrasensory perception.
Modified by maxnix at 6:51 AM 8/11/2007
