Code P0303
Mopar
Car: Infiniti Q45 1998
I got a check engine light last night and checked it was Misfire in cylinder 3. I took out the coil and the spark and everything seems to be ok. I put it back together and my car still chucks and vibrates and hesitates on acceleration. What do i need to change in a misfire, the coil or the plug or what?
Q45tech
Depends! could be a dirty injector or a dirty intake valve or plug or coil or ecu or bad rings [low compression].
One usually changes spark plugs, examines and cleans the coil boot and uses BG44K to clean injector and valves as the first step.
Mopar
ok done that, what do i do next? change the coil?
gjh20
Car: 2005 G35 Coupe, 2005 350Z Vert, 1989 300ZX
Mopar wrote:I got a check engine light last night and checked it was Misfire in cylinder 3. I took out the coil and the spark and everything seems to be ok. I put it back together and my car still chucks and vibrates and hesitates on acceleration. What do i need to change in a misfire, the coil or the plug or what?
i have the same problem, except my miss is so random that it won't trigger the check engine light so that i can single out the cylinder. i bought a new coil & have been playing "musical coil" to try to figure it out. i will seemingly have the prob identified & it'll run good for a few days, then the miss returns. i hope someone can help us out Mopar because $250 apiece for 8 coils is not easy to swallow (especially considering it may not solve prob).
Mopar
I am thinking of buying a coil and playing that cat and mouse game with my plugs, since today it turned into random misfire. don't know what to do! and I got so used to the shaking of the car at red lights that today i was sitting in a friend's car and it was so nice without the earthquake!. Please someone adivese.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
gjh20 wrote: i hope someone can help us out Mopar because $250 apiece for 8 coils is not easy to swallow (especially considering it may not solve prob).
Only ~$173 from Joe.
There are two types of coils on a VH41DE.
If a cylinder misses, there will be a code usually along with a KS code .
Modified by maxnix at 8:19 PM 6/5/2007
KU4FIZE
Car: Infiniti Q45
funny, i only got one code?
and 173 dollars for coils is it for all 8 or just 1 coil?
what type of coil do i need/looking for since there are 2 types.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Per coil pack. There are 2 different types, so it depends which type (which is dependent on the cylinder) you want to change out.
Only one code is fine. KS code is normallly also generated with a misfire.
gjh20
wow. was totally unaware of there being 2 diff coil packs. i bought mine from Infin & wasn't asked which cylinder the two were designated to replace. can you elaborate on how to know the differences a bit more? its a shot in the dark, but i may have wrong coil pack on wrong cylinders...
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Just look next time you are there. One type will not fit on the other type, I believe.
I may be wrong, but when I ordered from Joe I specified the cylinder where the coil pack was installed. In my case it was 2 and I switched with 4.
gjh20
i've pretty much exhausted the possibilities in the game of "coil switcheroo" & didn't have any coil fitment issues. i dunno. honestly, i'm frustrated as hell & just want it to go away.
ZMARKUS
Car: 1999 Infiniti Q45T
2002 Infiniti Q45
Amen brother, I feel the same way. Why in the hell is the issue so common but it seems the resolution evades everyone. Infiniti dealers with their bend over and take it high labor prices should be ashamed not to be able to identify this cause more efficiently.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Well, it's very simple. If the problem follows the coilpack, then it is the coilpack. If it does not, then it is the plug or the injector or their respective harnesses.
The above presumes you have a clean intake, TB, EGR and IAC valve, new fuel filter, air filter, properly working fuel pump. Must eliminate all else first.
Modified by maxnix at 8:29 AM 6/1/2007
Q45tech
To meet emissions idle AF is leaner than ideal, after the coolant warms up!
Does the misfire occur during warmup or after 10-15 minutes is a clue.
With a Consult you can manually increase/decrease injector open time to rule out lean misfire. How many 0.00 miisecs before other cyclinders misfire...how much is reserve.
One treatment with BG44k may not clean everything to as new condition.....why BG makes a rail flush system.
When you change spark plugs IMPORTANT to examine the piston crowns for deposits [fiber bore scope or just a fiber flashlight] ....the problem is seeing into the rear cylinders.
Gasoline may be the cause, as it is different from classical version used to test engines. Premium on the pump only means it costs more.
Change brands, change terminal fill locations, substitute some 100 octane racing fuel to zero in on the cause.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Yes, fuel may be erroneously presumed to be good. Tier one premium only from a new location.
Always worth running a bottle or two of ISO-HEET even before a can of BG44K just incase there is condensation.
Modified by maxnix at 8:20 PM 6/5/2007
Mopar
well my misfire happens AFTER my car warms up. But for the past 2 days the misfire went away?!?! only today at a stop light it misfired once and that was it?
gjh20
got 2 cans of 44k for $23 bucks. i am halfway thru the 1st can/tank & can easily notice a difference in engine response. thanks for the advice! i know i'm jumping the gun on this part (BG rep told me 2 run 1can/tank, thn a full tank, thn the 2nd can/tank), however, my mis is stronger than ever. i'll be patient until i complete the 44k process but i'm anxious to know the next piece of advice on how to fix/proceed.
btw, my miss occurs on start-up then frequently surfaces during idling, acceleration
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
gjh20 wrote:btw, my miss occurs on start-up then frequently surfaces during idling, acceleration
So tell us about the condition of the plenum, EGR and IAC valves, TB, lower plenum runners, and the EGR tube within the plenum. Fuel filters?
Any not pristine as new?
xerexabante
Car: '02 Infiniti Q45
'02 Nissan Maxima SE
check your plugs to see which one has more carbon build up. thus this will tell you that there is unburnt gasoline. might work
gjh20
maxnix wrote:So tell us about the condition of the plenum, EGR and IAC valves, TB, lower plenum runners, and the EGR tube within the plenum. Fuel filters?
as much as i hate to admit it, i can't answer any of these questions. i have moderate mechanic skills & honestly don't know what all those parts are or how to assess their condition.
gjh20
xerexabante wrote:check your plugs to see which one has more carbon build up. thus this will tell you that there is unburnt gasoline. might work
i'll check that. also, the miss didn't begin until i replaced the plugs during a major tune up a couple months ago.
Q45tech
AH HA! When you pulled the coil out to change the plugs you probably damaged it going out or back in...........................this occurs sometimes.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
gjh20 wrote:as much as i hate to admit it, i can't answer any of these questions. i have moderate mechanic skills & honestly don't know what all those parts are or how to assess their condition.
Couple of posts on removing the plenum to get to KS on Infiniti Online Mechanic. Only way to know is to look, or assume at 60K - 70K -80K+ miles if not known performed by then.
Modified by maxnix at 8:02 AM 6/9/2007
Qproject
could it be that maybe it's not related to the coil packs/spark plugs ?
I get a stall sometimes which triggers my "TCS traction control system" light to come on.
this happens very randomly.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Qproject wrote:could it be that maybe it's not related to the coil packs/spark plugs ?
Yes.
Coold be a failing alternator, failing battery, or both.
gjh20
Q45tech wrote:AH HA! When you pulled the coil out to change the plugs you probably damaged it going out or back in...........................this occurs sometimes.
assuming you may be correct, how would i isolate the failed/damaged coil if i am not getting any codes?
Q45tech
Chicken or egg, I wonder why they have upped the plug replacement [to 100k] interval? So the chance of creating a bad coil [at 60k service] rise beyond the powertrain warranty?
qship96
Car: 1996 Infiniti Q45
Q45tech wrote:Chicken or egg, I wonder why they have upped the plug replacement interval? So the chance of creating a bas coil rise beyond the powertrain warranty?
after looking at the infiniti service schedule on line at corporate website,it appears they dont even list any sparkplug changes anymore,lifetime plugs? check out the newer q or m45 service logs online !
Q45tech
Lifetime is a misnomer inthat legal lifetime is 100,000 miles.After that point the car is supposed to be retired and crushed/ sold for scrap.
Just because some last longer in not germain.
Qproject
ok so any updates on this ?
this has been the biggest mystery in y33 history.
